O yea, and also OIL Pressure wire.. ELECTRICAL Autometer
The oil pressure sensor. Find a wiring diagram and you can get the wire. If not, you may be able to use the VTEC solenoid's oil pressure sensor unit.
With the electrical oil pressure gauge you have to use the Autometer sender. Then with there sender to there guage.
I am almost positive you can not tap into the stock sender
