Oil Pressure Gauge Question
Old Feb 21, 2006 | 08:56 AM
themorphious's Avatar
Default Oil Pressure Gauge Question
I have just purchased a autometer 0-100 psi oil pressure guage. I am wondering if i have to hook up the sender that came with the gauge or can i just take the signal from the factory pressure sending unit right above the oil filter. 1994 Honda Civic d16z6.
Old Feb 21, 2006 | 08:58 AM
Boosted Power's Avatar
If I got what you're trying to say.
You can just T it off of the stock pressure sensor.
Old Feb 21, 2006 | 09:02 AM
Default Re: (Boosted Power)
well, the gauge is electric on the back of the guage and a wire runs to the sender that you would tee into the block, with pipe fittings and such. I am just amking sure that i can just run a wire from the sender terminal on the back of the gauge to the factory oil pressure sensor on the back of the block, above the oil filter.
Old Feb 21, 2006 | 09:06 AM
Default Re: (themorphious)
bump
Old Feb 21, 2006 | 09:20 AM
Si Shane's Avatar
The gauge is not calibrated to the voltage signal of your stock sender, you must put the new sender into the oil system where you want to measure the pressure.
There are a billion and 1 walkthroughs for this, try using the search function as it is more effective and faster than making a thread.
tundra2000
Sep 27, 2010 06:22 PM
cbabyby
Aug 8, 2007 01:21 PM
torqueless
Apr 19, 2007 03:29 AM
nicko360
Mar 14, 2007 02:52 PM
a1320honda
10
May 22, 2004 03:56 PM
