will a B18a throttle body fit dohc zc
nope it deff will not
only sohc tb's before 92 will fit it
ill trade you a d16z6 for it its a lil bigger than the stock zc and you can get rid of all that map bs because the map sensor is on the tb.
:edit: sorry the z6 tb wont fit the zc (read further)
Modified by spun Vtec at 2:22 PM 8/26/2003
ok let me see if i get this straight, the b18a tb fits on the sohc vtec, the sohc vtec fits on the dohc zc, but the b18a tb wont fit on the dohc zc ?
**** my bad i dont know what i was thinking. every sohc after 92 has the b series style tb so that means the z6 wont work on the zc. the only tb that will fit on the zc is the a6 or any fuel injected d series prior to 92.
z6
y8
and b series use the same bolt pattern
zc, a6 have a diff bolt patt.
and you cant put any other intake manifold on a zc (that i know of)
but i will buy it from you if you wana sell it (i have a y8 manifold) on my z6 head
z6
y8
90wagon4wd
Jan 9, 2004 06:01 AM
