installing power cable for subwoofer...which route should i take?
Old Aug 15, 2001 | 07:34 AM
IDE RaiD's Avatar
New User
Default installing power cable for subwoofer...which route should i take?
Hey guys, i know i'm not the only person who's tried to wire my car with an amp and a sub, but where the hell do i put the power cable going from the battery to the sub itself? i know how to hook it up, but i just can't find a damn place to put the wire through the firewall. lemme know where you routed the wire. thnx guys. :D
Old Aug 15, 2001 | 09:21 AM
96honda accord EX's Avatar
New User
Default Re: installing power cable for subwoofer...which route should i take? (IDE RaiD)
I think theres a hole rite under the master.i didn't hook up my music though but i think so
Old Aug 15, 2001 | 12:40 PM
IDE RaiD's Avatar
New User
Default Re: installing power cable for subwoofer...which route should i take? (96honda accord EX)
alright, thnx for your suggestions but i just ended up routing it up through the passenger side dash to the fender wall, out through the engine bay, and to the battery. btw, i didn't hook up the sub DIRECTLY to the battery, i went through the amp. however, now that everything's hooked up and working properly (or so i thought), it makes a weird thumping noise immediately after i turn off the head unit. yes, i know subs are supposed to thump, ( .|.. ..|. ) but this is unusual. any suggestions on why it's making that last thumping noise when the unit is turned off? it's not a popping noise. thnx for suggestions.
Old Aug 16, 2001 | 05:10 AM
CardDealer's Avatar
Banned
Modified by CardDealer at 4:17 AM 11/16/2006
Old Aug 17, 2001 | 11:04 PM
New User
Default Re: installing power cable for subwoofer...which route should i take? (schlit)
yea thats a good way through the fire wall
Old Aug 19, 2001 | 05:59 PM
emay1993's Avatar
New User
I bet I know your problem. If you ran the power cord along beside the RCA cord, the RCA picks up the engine noisy for some reason. The best way for you to do it, and any proffesional will back this up, is to run your power cable along the different side of your car than your RCA cable is. Its really best to go under the steering column into the firewall. There are usually small rubber gromets that you can pullout and harmlessy drill into the firewall. Anyways hope this helps our your problem.
-Eric
Yun_Ej2
Audio / Security / Video
12
Sep 11, 2010 06:13 PM
tougetuned_ef
May 19, 2009 10:03 AM
sacredc0w69
10
Sep 10, 2003 04:53 PM
crxguy05sir
May 18, 2003 05:42 PM
Agent Daimon
Sep 3, 2002 06:46 PM
