Climate Control Broken?
Old Aug 24, 2003 | 07:01 PM
RedKroovy's Avatar
Default Climate Control Broken?
Well the warranty is coming up soon and I was going over the car and fact that the cc system runs all the time is the only thing I can find. I've asked a dealer before and they said it was air infiltration. It will come through the last vents that were selected when the system was last used. Also when I change the temp switch the temp of the air will change slightly. So finally is this normal or is my cc system broken. Thanks for your help.
Old Aug 24, 2003 | 07:26 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Climate Control Broken? (RedKroovy)
Huh?
I don't recall my Hype R having a "climate control" system. I thought it just had the fan speed setting and the temp setting (blue-red, not actual degrees). So what you set it on is what it's going to run until you change the settings.
hinge24
Honda Fit
Sep 22, 2017 12:39 AM
DC206R
May 6, 2009 04:00 PM
phistahh
Honda Civic (2001 - 2005)
Dec 16, 2008 01:27 PM
ScoobCivic
Aug 2, 2004 02:11 PM
technine
Sep 16, 2002 01:28 PM
