abs light
Old Aug 15, 2001 | 06:47 AM
redteg1's Avatar
Default abs light
it turns on and stays on when i drive...wats goin on? abs not working or something?
Old Aug 16, 2001 | 08:23 PM
joemama's Avatar
New User
Default Re: abs light (redteg1)
i have the same problem but it comes and goes
Old Aug 17, 2001 | 01:11 PM
JSpecwest's Avatar
New User
Default Re: abs light (joemama)
Could be a blown fuse. Check your ABS fuse box.
Old Aug 17, 2001 | 02:10 PM
BreakStuff's Avatar
New User
Default Re: abs light (JSpecwest)
Does the Light come on and then go off when you first start the car?
Does the light come on and stay on when the car is started in park?
Does the light come on when the vehicle is in motion?
Old Aug 17, 2001 | 02:21 PM
G's Avatar
G
You can read the abs codes the same as reading the ecu codes. Breakstuff, correct me if I am wrong. If there is a malfunction in the abs system, the light will come on. If you purposely disable the abs, the light will come on....... Check for codes.....
Old Aug 17, 2001 | 04:42 PM
redteg1's Avatar
Default Re: abs light (G)
oh its off now...hehe must be a come and go thing..hmmm
Old Aug 17, 2001 | 06:01 PM
G's Avatar
G
Check for codes. The abs can still have trouble codes stored, even if the abs light goes off.....
Old Aug 17, 2001 | 08:03 PM
BreakStuff's Avatar
New User
and check the brake fluid level in the ABS brake fluid reservoir !
heya G, I get my secret tool next week! , Snap-On guy didn't have one on the truck... $45 seemed kinda steep, but I figure it will pay for itself
Old Aug 18, 2001 | 02:42 PM
G's Avatar
G
Default Re: abs light (BreakStuff)
The "secret" tool..... You should be ashamed that you're only getting it now, at least for home use. I know you don't want to finish valve adjustments toooo fast at work, hehehe. I was doing it with a screw driver, then tightening with a rachet (no space for a wrench in those darn vtec heads), then loosening it and tightening it all over. What a mess! The TOOL will be your friend. Do you have the flywheel locking tool? Can you send me one for my H22a? Buddy, friend, pal...........Sponsored by Honda.....
cdoucet
Jan 28, 2006 04:08 PM
94~GSR
Sep 30, 2005 10:33 PM
vtran8
Jul 14, 2003 01:02 AM
CNSK
Apr 12, 2003 11:13 PM
oioioi
Oct 11, 2002 02:47 PM
