knocking y8 for 175 worth it?
Old Aug 24, 2003 | 05:47 PM
JonGP4's Avatar
Default knocking y8 for 175 worth it?
my local junkyard has a d16y8 block and head, he said he wants 175 for it but its knocking, head is good but block knocks, he thinks the number 1 rod journal is bad. is this worth rebuilding?
Old Aug 24, 2003 | 05:54 PM
I8ayellowcrayon's Avatar
I was actually considering buying a Y7 (non-VTEC) for $125 with a knock. The head on the Y8 is worth that. I would suggest buying it, and looking around for a Z6 or even another Y8 block. You can get them for less than the head usually because its basically just a 1.6 block without the head. Or you could use a D16A6 or D15B7..... I'd go for it.
Old Aug 24, 2003 | 06:18 PM
civickiller's Avatar
Default Re: (I8ayellowcrayon)
but u gotta worry about what caused the knock, runnin no oil. well u gotta make sure the head is good. because if the block was run with no oil, cause the rod bearing to fail, then the head might be fucked up.
if u can find another block, but not worth a rebuild, unless u can grind the crank and get new rods for cheap. my rod bearing went in my ls, gonna cost me $600 to rebuild the bottom end with stock parts
Old Aug 24, 2003 | 06:40 PM
mildly.interesting's Avatar
Default Re: (civickiller)
yup, the head is worth it...
lilsicsoul
Aug 4, 2009 06:20 PM
eg9matt
Jul 20, 2007 05:51 AM
xci_ed6
Dec 13, 2004 09:57 AM
crashtest Sonny
Aug 9, 2003 02:51 PM
