B18B. y0.
Old Aug 24, 2003 | 04:37 PM
Attoir's Avatar
Default B18B. y0.
Got an '88HF. OBD I conversion, the last engine in it was a D16Z6.
Was running a '90 CRX SI Ecu
What wiring am I going to have to do to drop in a B18B?
Old Aug 24, 2003 | 04:49 PM
civickiller's Avatar
Default Re: B18B. y0. (Attoir)
how could your obd0 ecu be runnin your obd1 motor.
also it depends on the year of the b18b, it could be a obd1 or 2
Old Aug 24, 2003 | 05:25 PM
onePOINTsix's Avatar
Default Re: B18B. y0. (civickiller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">how could your obd0 ecu be runnin your obd1 motor.</TD></TR></TABLE>easy, just put on stock intake manifold and TB and distrubiter and convert you ecu into a 1-wire vtec setup or run a rpm bactivated switch
Old Aug 24, 2003 | 06:13 PM
Default Re: B18B. y0. (Sideout)
then its not a obd1 conversion, its a z6 obd1 converted back to obd0, so its the reverise, ob0 conversion
he said obd1 conversion, so he must be runnin the obd1 parts, so how can the obd0 ecu run the obd1 parts
VTEC_Honda
Jun 1, 2011 03:54 PM
Damills
Nov 4, 2008 10:38 AM
MniMeHatch89
May 24, 2007 09:10 PM
