ITR motor idle too high
Old Aug 24, 2003 | 04:13 PM
daddymaxx's Avatar
Default ITR motor idle too high
Ok here's the situation. I have 99 spec JDM ITR motor in my EK. Now I have a 97 JDM ITR ecu, and a 99 JDM ITR ecu..
I'd rather use teh 99, because it's the right one for my engine.... but with that one I don't have fast Idle. It seems to idle too low when teh motor in cold. But when it heats up it ilde perfect. I can adjust the idle screw and set it perfect. but only when it's warm.
Now I have the 97 ECU aswell, and I like this one, because the fast idle seems to work. When it's cold it idles at 1500 like normal, but when it warms up it goes down to only 1100 rpm. And when I screw around with the idle screw it goes down, but then goes back up to around 1100.
Anybody have any input? I set the idle with the service conector jumped.... And when I tried to set the idle with the IAVC unpluged, the rpm dropped, then I set it at about 550, the plugged it back it, and it jumps up to 1500 (while engine warm) and kinda backfires a bit.
Any help appreciated!
thanks in advance
Old Aug 24, 2003 | 05:04 PM
tour de france turbo's Avatar
Default Re: ITR motor idle too high (daddymaxx)
you might have some air in the radiator.
Old Aug 24, 2003 | 05:25 PM
Nameless RB26's Avatar
Default Re: ITR motor idle too high (stock ek sleeper)
Are you giving the ecu time to learn the engine again? You need to drive it and start it alot before it will learn.
Make sure you have the vacuum port on the backside of the intake manifold plugged too. It's for cruise control and I'll bet you don't have that. It will cause major idle probs.
Old Aug 24, 2003 | 05:45 PM
daddymaxx's Avatar
Default Re: ITR motor idle too high (Nameless EJ6)
yea I plugged that. How long do I have to drive it for? I don't think it could be air in the radiator. But the other ecu idles fine when it's warm.
downshift3r
Sep 30, 2013 06:34 AM
turbohatch96y7
Engine Management and Tuning
Jun 10, 2013 07:42 AM
dth0ng69
Mar 7, 2009 11:21 AM
djmatix
Aug 11, 2007 12:45 PM
daddymaxx
Aug 25, 2003 10:01 PM
