B16A head or GSR head?
Old Aug 24, 2003 | 03:31 PM
Skyllz's Avatar
Default B16A head or GSR head?
I got a 98 GSR bloc/head/intake sitting here almost ready to go in my EK...
Eventually I want to turn this into a N/A screamer.
Some people swear by the B16A head, other say the GSR one is better, soemthing I dont know yet about the combustion chamber shape and the way the ports are shaped?
The head will be port/polished and all, long term goals are ITBs. Of course all the head work will be done by a pro that knows what he is doing...
The bottom end would stay mostly stock except maybe for new rings and rebalance the whole thing this winter.
Any opnions or experiance anyone wants o share on this?
Old Aug 24, 2003 | 04:52 PM
TwoRedEGgs's Avatar
Default Re: B16A head or GSR head? (Skyllz)
If you are getting the head PNP's then i would use a GSR head cause it will net your a higher compression using the same components! The reason for this is due to the way the chambers are, very similar to the K series motor ! They flow very similar stock but once u get them PNP'd then it's up to how good the job is done. Some ppl may disagree but this is what i would do !
Old Aug 24, 2003 | 05:08 PM
DOHC SOLDIER's Avatar
Default Re: B16A head or GSR head? (TwoRedEGgs)
if you fully do the b16 head which means welding the combustion chambers and what not, than i would say the b16 head, but if your just gonna port the head then go with the gsr. you already have a gsr head anyways so use that. its just easier
Old Aug 24, 2003 | 10:09 PM
rodimus's Avatar
Default Re: B16A head or GSR head? (DOHC SOLDIER)
gsr head = higher compression/pentroof style chambers (like the well flowing rsx heads)
plus the gsr head is probably newer since most b16 heads out there are 1st gen..
gsr prolly has better LMA's if the b16 head is 1st gen.
plus u already have the gsr head.
trust me..do a thread search under my user name.
Old Aug 24, 2003 | 10:39 PM
NA gs-R 05 C
Guest
Posts: n/a
if your bottom end is staying fairy stock, and you're sure that you're gonna do port work to whichever head you get, then i think you should choose the gsr head being that it can bump compression.
spoon95eg
Feb 26, 2006 01:16 PM
hb4u2nv
Jun 13, 2004 03:37 PM
VtecRacaChick
Jan 29, 2004 10:30 PM
S@nt0s
Jan 17, 2004 08:19 PM
Petah
Oct 27, 2001 09:19 AM
