FI fuse?
You can get away with pulling all three if you needed to, or just pull one at a time and try turning your car over. If it starts, then you pulled the wrong one. I never even bother pulling fuses during a compression test... I just pull the wires and go. When I start the car again, all the built up fuel makes the car run rough for a second or two, but it comes back to life when it burns the fuel away anyway.
Either way, your choice. I don't think letting the fuel spray into the cylinders with no spark hurts anything, but might as well pull the fuses since you're there. Peace!
StolenTeg
Oct 10, 2004 03:51 PM
Tad
Jan 31, 2004 07:26 PM
