what msd igntion is good and has .......
Old Aug 24, 2003 | 02:41 PM
civictypenos's Avatar
Default what msd igntion is good and has .......
what msd igntion is good and has boost timing retard built into it?
Old Aug 24, 2003 | 02:47 PM
Foozball26's Avatar
Default Re: what msd igntion is good and has ....... (civictypenos)
the msd 6 BTM has a retard control on it, but its only adjustable from 1-3 degrees per lbs of boost, and 1 degree per lbs is too much for a honda.
Old Aug 25, 2003 | 04:35 AM
Default Re: what msd igntion is good and has ....... (Foozball26)
it does not have the adjustable ****??my btm has an adjustable **** that goes 0-4.im trying to find out for a freind,what complete ignition would be good for him,i just use the seperate btm system on mine.
Old Aug 25, 2003 | 05:37 AM
DA-MAX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Foozball26 &raquo;</TD></TR><TR><TD CLASS="quote">the msd 6 BTM has a retard control on it, but its only adjustable from 1-3 degrees per lbs of boost, and 1 degree per lbs is too much for a honda.</TD></TR></TABLE>
I hear you can run partial as well like say you put the **** between 0 and 1 is .5 degrees retard and so on
Old Aug 27, 2003 | 05:34 PM
Foozball26's Avatar
Default Re: what msd igntion is good and has ....... (DA-MAX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA-MAX &raquo;</TD></TR><TR><TD CLASS="quote">
I hear you can run partial as well like say you put the **** between 0 and 1 is .5 degrees retard and so on</TD></TR></TABLE>
Not sure, all the ads say is between 1-3 degrees per lbs and yes it has a **** to adjust on the fly.
layedoutat0psi
13
Nov 20, 2007 12:34 PM
b18tdelsol
May 1, 2002 11:25 PM
zip
Jan 28, 2002 06:37 PM
