CEL code
Old Aug 24, 2003 | 02:02 PM
TTWS6.
Guest
Posts: n/a
Default CEL code
whats a 19 on a p28, My friends ghetto manual says I think "lock up solenoid" whats that?
Old Aug 25, 2003 | 07:23 AM
TTWS6.
Guest
Posts: n/a
Default Re: CEL code (TTWS6.)
ttt
Old Aug 25, 2003 | 09:32 AM
Kataku2K3's Avatar
Yup it's an automatic transaxle lock up code... All it means if you have an AUTOMATIC ECU... There's nothing wrong with it especially if you're running a chipped ECU... You can get rid of the code by simply opening up the ECU, cutting RP17 and PR18 which are located directly under your ROM 27256 slot next to the barometric pressure sensor (in most ECU's)... Once you have the resistors cut and desoldered out with a piece or wire (or I use the solid wire from the leg of a resistor) jump RP18 and close up the ECU... After that you should be set with no CEL... Hope this helps, Peace
Old Aug 25, 2003 | 10:51 AM
TTWS6.
Guest
Posts: n/a
Default Re: CEL code (Kataku2K3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">Yup it's an automatic transaxle lock up code... All it means if you have an AUTOMATIC ECU... There's nothing wrong with it especially if you're running a chipped ECU... You can get rid of the code by simply opening up the ECU, cutting RP17 and PR18 which are located directly under your ROM 27256 slot next to the barometric pressure sensor (in most ECU's)... Once you have the resistors cut and desoldered out with a piece or wire (or I use the solid wire from the leg of a resistor) jump RP18 and close up the ECU... After that you should be set with no CEL... Hope this helps, Peace</TD></TR></TABLE>
but I have a 5 speed, never been modified. I bought it from an old doctor, car has never been modded except for the tinted windows. so are u sure?
Old Aug 25, 2003 | 03:05 PM
TTWS6.
Guest
Posts: n/a
ttt
Old Aug 25, 2003 | 07:52 PM
Kataku2K3's Avatar
Default Re: (TTWS6.)
Just to check, open up the ECU and look over the set of RP resistors and jumpers... If you find that RP17 is empty and RP18 has a jumper (looks like a resistor with a 0 ohm rating, only a black stripe) then in fact you have a manual ECU... If it looks any different than that then ECU's have most likely been swapped... If it is indeed a manual ECU then I'm not sure why you're getting your 19... Sorry I couldn't be more of a help, Good Luck again...
Old Aug 25, 2003 | 08:43 PM
PHiZ's Avatar
Default Re: (Kataku2K3)
Your car is undoubtedly about to blow up. Run for cover.
http://216.239.39.104/search?q...UTF-8
-PHiZ
Old Aug 26, 2003 | 05:25 AM
TTWS6.
Guest
Posts: n/a
Default Re: (PHiZ)
I have 19 on this list http://216.239.39.104/search?q...UTF-8
Lock-up Control Solenoid
Possible cause : Open or short in LCS circuit, defective LCS solenoid
whats the Lock up control solenoid??
Old Aug 26, 2003 | 09:32 AM
PHiZ's Avatar
Should only appear on auto ecus/cars. what lead up to this, or did it just happen randomly?
-PHiZ
slowpokecivic
Feb 20, 2007 04:59 PM
senpai
Oct 22, 2004 08:47 AM
Brewer
Jul 7, 2004 01:49 PM
turboex
Aug 29, 2003 06:57 AM
4drGSR
Feb 23, 2002 07:40 PM
