bleeding coolant
Old Aug 24, 2003 | 12:32 PM
true's Avatar
Default bleeding coolant
I've been having tons of trouble with my coolant system on my turbo crx with 97 typer engine. I have the 95 gsr helms, and 97 type-r helms suppliment. Well, I can clearly see the GSR has a bleeder bolt on the upper pipe for coolant bleeding assitance......the Type-R does NOT have this. Obviously I can't follow the gsr bleed procedure... anyone have a 98 helms or something that shows a different method (if one exists) for bleeding coolant in a typer engine? Thanks....kinda related thread probably at: https://honda-tech.com/zerothread?id=294757
Old Aug 24, 2003 | 12:34 PM
ragejed's Avatar
Default Re: bleeding coolant (true)
open rad cap, run car with heat on.
Old Aug 24, 2003 | 01:01 PM
true's Avatar
Default Re: bleeding coolant (ragejed)
Ok..I'll have to come up with something else..that's what I've been doing. Wanted to make sure that the type-r really doesn't have the bleed bolt..and also wanted to verify they don't have a different procedure.
Old Aug 24, 2003 | 01:06 PM
ragejed's Avatar
98-01 gsr doesnt have a bleed bolt either.
PphamEK
Mar 16, 2009 12:43 PM
WalkerGSR1
Oct 25, 2006 10:17 AM
true
Sep 7, 2003 05:23 PM
JL 74
Mar 8, 2002 08:46 AM
Pat
Aug 23, 2001 08:33 PM
