ZC pistons in D15B7? Just making sure
Old Aug 24, 2003 | 11:53 AM
I8ayellowcrayon's Avatar
Default ZC pistons in D15B7? Just making sure
I'm almost positive they will fit with no boring or any other major mods, but I am just wanting to make sure that they will.
Old Aug 24, 2003 | 01:14 PM
RedRacerCivic's Avatar
Default Re: ZC pistons in D15B7? Just making sure (I8ayellowcrayon)
yes they will fit, they share the same 75mm bore.
Old Aug 24, 2003 | 01:32 PM
The Brown Kid's Avatar
Default Re: ZC pistons in D15B7? Just making sure (RedRacerCivic)
i wonder what the c/r would be and if there is any clearance issue
Old Aug 25, 2003 | 12:17 AM
JaeOne3345's Avatar
Default Re: ZC pistons in D15B7? Just making sure (The Brown Kid)
I've discussed this before.
if you want to put d16 pistons in a NON VTEC d15, you better make sure you get rods from the VX 1.5 vtec-e motor or the jdm sohc vtec d15b. If you use the non vtec rods, the piston will sit down in the hole about 3mm too short due to piston/deck height differences and rod length differences. thus a waste of time and a loss of compression.
Old Aug 25, 2003 | 02:16 AM
civickiller's Avatar
Default Re: ZC pistons in D15B7? Just making sure (JaeOne3345)
yes it will fit, suppose to yield higher comp ratio too
Old Aug 25, 2003 | 02:18 AM
JaeOne3345's Avatar
Default Re: ZC pistons in D15B7? Just making sure (civickiller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">yes it will fit, suppose to yield higher comp ratio too</TD></TR></TABLE>
read above, they will sit too low in the hole.
Old Aug 25, 2003 | 02:27 AM
[626]95-GSR's Avatar
OT: but where can i get some d16a1 pistons for my rebuild.. its going in an a6 block of course..
Old Aug 25, 2003 | 02:46 AM
JaeOne3345's Avatar
Default Re: ZC pistons in D15B7? Just making sure ([626]Rj-SiHatchy)
your acura dealer.
or http://www.acuraautomotiveparts.net 1988-89 d16a1 p29 pistons.
Old Aug 25, 2003 | 03:17 AM
hes not putting vtec pistons in his b7, hes putting zc pistons in his b7. why does the vtec rods matter ? well my friend put zc pistons in his b7 and it was faster, but i guess it was something else that made him faster after he put those pistons in
Old Aug 25, 2003 | 07:21 AM
JaeOne3345's Avatar
because the d15 and d16 pistons have different heights. a d16 rod is longer then a d15 rod by about 3 mm. when u put the d16 piston on the shorter non vtec d15 rod, the piston sits lower in the hole.
did i say anything about vtec pistons? i said vtec rods. the vtec d15 rods are different then other 1.5 non vtec rods. you could say they are similar to a 1.6 rod in nature. they keep the piston up in the hole where i should be, so it doesnt sit too low in the hole. sure u may see a lil gain. but, not worth the trouble if the piston is gonna sit too low. i bet your friends car would be faster with proper rods.
Old Aug 25, 2003 | 10:00 AM
slywfbpsi's Avatar
If you were to be using a regular d16 piston on your d15 rods, your compression would be around 8.6 but since you are looking to use zc pistons, which are domed, you would raise your c/r to 10.71.
Old Aug 25, 2003 | 02:38 PM
teamrushhatch's Avatar
Default Re: ZC pistons in D15B7? Just making sure (slywfbpsi)
arite i want to put zc pistons inside of a z6 or get some pistons to install into the z6 what pistons can i use that... and what compression will the a1's/p29s yield me!
Old Aug 25, 2003 | 02:44 PM
slywfbpsi's Avatar
Default Re: ZC pistons in D15B7? Just making sure (teamrushhatch)
I already answered that question, a1/p29 would give you 10.71 on b7 rods.
Old Aug 26, 2003 | 05:53 PM
what about the pm7 pistons in the z6
Old Aug 26, 2003 | 06:16 PM
slywfbpsi's Avatar
12.03
Old Aug 26, 2003 | 06:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slywfbpsi &raquo;</TD></TR><TR><TD CLASS="quote">12.03</TD></TR></TABLE>
Nice. Yeah, I didn't want to use the D15 rods, I've always heard about problems with heat dissipation, and I wanted the ZC rods for more strength because I am planning on running boost. Oh well, it was worth the try. But they will fit fine in an A6? (PM7 pistons/rods)
Old Aug 26, 2003 | 07:28 PM
Broken Gearbox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I8ayellowcrayon &raquo;</TD></TR><TR><TD CLASS="quote">
Nice. Yeah, I didn't want to use the D15 rods, I've always heard about problems with heat dissipation, and I wanted the ZC rods for more strength because I am planning on running boost. Oh well, it was worth the try. But they will fit fine in an A6? (PM7 pistons/rods)</TD></TR></TABLE>
yea, the PM7 pistons/rods will fit in the D16A6.
hinds90
Aug 22, 2005 09:23 PM
crxxxxxx
Sep 12, 2004 02:28 PM
jap-in-da-box
Sep 8, 2004 03:21 AM
NoBoost
Feb 19, 2003 07:37 AM
