My car keeps stalling..
Old Aug 14, 2001 | 08:57 PM
91ED7Si's Avatar
Default My car keeps stalling..
when ever i start it up it runs for about a second then the gauges die down and the engine sputters for a second then dies..
if i hold the gas down it starts fine but only after holding the revs up for a second..
what could be the problem?
oh btw the check engine light turns on right when the gauges die down but then turns right off..
Old Aug 15, 2001 | 12:06 AM
91ED7Si's Avatar
Default Re: My car keeps stalling.. (91ED7Si)
My friend says its vapor lock?
wtf is that and how serious is it?
Old Aug 15, 2001 | 01:55 PM
EVOCELICA's Avatar
New User
I could be wrong but it sounds like your battery might be weak and you are not getting full ignition spark, which makes sense because when you give it gas the alternator is sending a charge to the battery because the motor is spinning. Do you have any problems cranking the motor over. I might be wrong but Vapor lock is when a unwanted liquid, water gets in to the combustion chamber, can some one please correct me if I am wrong.
Old Aug 15, 2001 | 02:29 PM
nawoj's Avatar
Default Re: My car keeps stalling.. (EVOCELICA)
mine does the same friggin thing!
but only every once and awhile
ive been told that it may be the main relay for the fuel pump, but i dont know cause its isnt happening as frequently now,
no idea what it could be.
when it does die will it not turn over right away after?
Old Aug 16, 2001 | 06:40 AM
$criptah's Avatar
New User
Default Re: My car keeps stalling.. (nawoj)
It might be that your battery is too weak to hold the charge or that your altenator is screwed up.
Old Aug 16, 2001 | 11:28 AM
91ED7Si's Avatar
no it allways turns over fine..
and then the motor cranks right up and sits at about 1500rpm then the tach goes all the way to 0 then the motor sputters down to a stop.
i added a quart of oil today and ive started it 3 times and it hasnt done it since..
so that might have been the problem[its burning a quart every 1500 miles!]
Old Aug 16, 2001 | 01:39 PM
nawoj's Avatar
ouch, burning oil is bad
i need a new muffler!
Old Aug 18, 2001 | 12:33 AM
brad.'s Avatar
sounds like you guys need some swappage goin' on
Old Aug 18, 2001 | 02:30 PM
evo's Avatar
evo
New User
Default Re: My car keeps stalling.. ([626]JDM-b16a-EF9)
My car has the same problem too, but only occured when the day is really hot.(about 28C-35C)
Old Aug 18, 2001 | 06:16 PM
91ED7Si's Avatar
Default Re: My car keeps stalling.. (evo)
yeah its been hot when ever it happened to me too.
i cant wait to get this poopy dseries out of there im all ready sick of how fast it is.
Old Aug 19, 2001 | 08:11 AM
evo's Avatar
evo
New User
Someone told me adjust the idle, has anybody know how to adjust the idle on B16A1??
many thanks!
Old Aug 19, 2001 | 11:36 AM
dustin's Avatar
Check the rotor in your distributor..
Old Aug 19, 2001 | 12:30 PM
EG8R's Avatar
Default Re: My car keeps stalling.. (dustin)
last time mine stalled the timing belt jumped.... i slipped it back on it the right place and i was off raci.... i mean driving
Old Aug 19, 2001 | 02:48 PM
nawoj's Avatar
Default Re: My car keeps stalling.. (skelly)
mine just did it again!
no reason
started strong
idled for a second or two
then died.
Old Aug 20, 2001 | 09:51 AM
brad.'s Avatar
adjusting the throttle body- there a big flathead screw that faces horizontally on the intake manifold...try that
Old Aug 21, 2001 | 10:31 AM
88_SC_CRX_Si's Avatar
New User
Vapor Lock - is when the fuel line gets to hot and gas/vapors keep the fuel from following. Only heard of it happening to carb'ed cars tho, not EFI.
Hydrolic Lock - is when you get a liquid trapped in the cylinder, while both sets of valves are shut, and does not let the piston finish it's strock, thus bending the rod.
Old Aug 22, 2001 | 07:53 AM
Customcrxsi's Avatar
New User
turn your key switch to the second position before it starts look at the ecu and see if it throws any codes. It should .
Old Aug 22, 2001 | 08:48 AM
91ED7Si's Avatar
Default Re: My car keeps stalling.. (Customcrxsi)
ive solved the problem it was caussed by low oil pressure cuz i allways got my right foot stomped to the floor and i burn hella oil this way.
kicker1_solo
Apr 25, 2008 09:26 PM
datssoled
Jul 12, 2007 04:14 PM
mustang5.slow
Mar 17, 2007 01:28 PM
canuk-sol
Nov 7, 2005 06:00 AM
Fowler.
10
Aug 20, 2004 05:26 PM
