How do you remove the passenger air bag?
take the glove box out, up under the dash theres a plug( i belive its yellow) thats for the air bag, unplug that and get a long extension to loosen 4 bolts and then it just pops out the top, one you get you glove box door off and look up in there its pretty self explanatory.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nekkedR »</TD></TR><TR><TD CLASS="quote">take the glove box out, up under the dash theres a plug( i belive its yellow) thats for the air bag, unplug that and get a long extension to loosen 4 bolts and then it just pops out the top, one you get you glove box door off and look up in there its pretty self explanatory.</TD></TR></TABLE>
Exactly.
I used a universal joint on my ratchet because the angle was a little odd to get to the bolts. I also had to use two ratchet extensions to get the proper length. But, it is an easy job but still requires some care because air bags are explosive devices. I also removed the dashboard cover from the airbag, and put it back into the dash, so I can cover the hole in the dashboard.
Exactly.
badream20
13
Jul 11, 2005 07:34 PM
Deemeetree
Jun 10, 2004 12:09 PM
