is it my pressure plate or clutch master cylinder
93 Prelude S
94 H22 usdm motorswap
tranny stock
Clutch isnt fully disingaging shutters when in gear and clutch pedal is to floor.. gears are not going in sometimes and they are grinding... everything is telling me that the clutch is not pulling off of the flywheel...
When driving in gear it sounds and runs fine just when you press the clutch in are there problems
so is my pressure plate shot, needs adjusted or does it sound like the clutch master cylinder?
When it first happend i thought the clutch fluid was full but it just left a shadow once i opened it i found it dry.. i filled it bled the lines and it didnt fix... this is why im thinking the clutch master cylinder went out.. but someone is telling me they think it is the pressure plate
any experience with this problem?
i want to get some experianced answers before i go pull the tranny off
tranny stock
if the master cylinder gets to low on fluid you will get air in the system. You can also check to see if the master cylinder is leaking from under the dash. If it is wet around the rubber boot it shouldn't be.
Surestick
Aug 23, 2006 10:56 AM
BoostedD15B7
Feb 5, 2003 06:57 AM
