help!!! w/ lca bolt
Old Aug 14, 2001 | 05:13 PM
b18bvudoo's Avatar
New User
Default help!!! w/ lca bolt
we got the nut off w/ the help of breaker bar, but bolt wont slide out...do you hammer it out??
Old Aug 15, 2001 | 11:38 AM
Lei Siew Long's Avatar
Default Re: help!!! w/ lca bolt (vudoo666)
are you referring to the spindle nut on the axles? if not, and you're referring to the bolt that bolts the shock to the lower control arm, then after taking the nut off the bolt, you hit the bolt with a ratchet to as far as it can go. after that, just pull and spin the bolt to get it off.
Old Aug 15, 2001 | 12:46 PM
3rdShift.org's Avatar
New User
Which side did you get the nut off? Depeneding on how old the car is, the bolt may be seized in the sleeve that runs through the lower part of the strut & LCA. I would reccommend purchasing an extra bolt in the case that you break the head off the bolt or end up having to cut it out & replace it. Good luck, as this is one of the biggest problems that I've run into on my car. I broke both sides off w/ a breaker bar.
Old Aug 15, 2001 | 12:53 PM
b18bvudoo's Avatar
New User
Default Re: help!!! w/ lca bolt (3rdShift.org)
how did you get the rest of the bolt out then if it was seized to the bushings?? i'm thinkin of just cutting the bolts out somehow.
Old Aug 15, 2001 | 12:57 PM
madhatter's Avatar
From: boldly scornful of higher mental function, US
The bushing has a steel sleeve running through it. That is probably what is seized.
Old Aug 15, 2001 | 10:29 PM
civicrr's Avatar
Default Re: help!!! w/ lca bolt (madhatter)
When that bolt gets stuck, they usually end up breaking. At my friend's shop, they usually end up having to put a new bushing & bolt in.
Old Aug 16, 2001 | 05:39 AM
fatoldman7's Avatar
New User
Default Re: help!!! w/ lca bolt (civicrr)
Do a search.... We coverd this topic about a month ago...and break out your drill.
Old Aug 16, 2001 | 08:14 AM
REDBARON's Avatar
Default Re: help!!! w/ lca bolt (fatoldman7)
If you're talking about the bolt that connects the LCA
to the brake hub. Then after you take the nut off, just
hit the end that you took the nut off with a hammer so the
head of the bolt goes out. Then use a rachet and a
wrench. Put the wrench behind the head of the bolt, and
while your pulling the bolt farther out, use the rachet
to turn the bolt simultaneously. This should work fine.
That's if we're talking about the same bolt. Hope this
helps you.
stevevang
Mar 27, 2016 04:46 AM
commotion
Mar 3, 2009 07:24 PM
pearlteg
Jan 24, 2005 07:36 PM
OneDirection
Suspension & Brakes
13
Jan 17, 2005 07:19 AM
flip b18b
Jun 28, 2004 10:31 PM
