NEED HELP ASAP
Old Aug 23, 2003 | 06:31 AM
tbocrx's Avatar
Default NEED HELP ASAP
stupid question for you guys...im installing an air-fuel and boost guage into a 2000 si....what color wire under the dash is for the power and what for the ground....also....i believe i can hook the air-fuel up to the all white wire going into the ecu.....does that sound correct?....help quick...im in the middle of the install and stuck.....
Old Aug 23, 2003 | 09:53 AM
RCautoworks's Avatar
Default Re: NEED HELP ASAP (tbocrx)
For power, you can splice into the one igntion wire that supplies power when you turn the key, its black and yellow. For a ground use a good metal surface.
91-ef-hatch
Sep 21, 2007 06:35 PM
whiteej1
Sep 14, 2006 07:41 PM
94preludeguy
May 12, 2006 02:13 PM
RTW DC2R
Apr 24, 2006 06:08 PM
Sirus
Oct 5, 2002 09:04 PM
