*PICS*, which coolant line do i get coolant for turbo?
You want to use the path that circulates the water thru the throttle body and IAC. The WATER BYPASS HOSE on your diagram. Remove the steel transfer pipe, (the one that is attached parallel to the valve cover breather), and connect one hose to the 8mm hose barb that comes off of the larger bypass hose barb. Connect the other hose to the 8mm hose barb on the throttle body or on the Iac on the throttle body depending on how your car is set-up. It does not matter which of the two hoses from the turbo center housing connects to each of these two hose connection, just that there is water circulating
can you use mspaint and draw lines? i'm getting confused.. yes since my intake install, i took off that metal pipe paralelle to my intake.. so i'ts just the bypass line from my TB to the block..
but it says "bypass"
does it mean after warm up it doesn't pass coolant?
ok that "bypass" line.. so i do this..
from TB, break off hose, then put hose FROM TB to turbo IN.. then from TURBO OUT go into the MANIFOLD where that line i cut...
is this ok???? will i get coolant 24/7?
you'll get it 24/7 even from the bypass line
Modified by D-Man at 9:27 PM 9/8/2003
Modified by D-Man at 9:31 PM 9/8/2003
