Ecu red lining at 7,700 rpm???
Old Aug 23, 2003 | 01:49 AM
SupaFly_Honda's Avatar
Default Ecu red lining at 7,700 rpm???
hey guys I just recently got done with a jdm b16 sir2 into my 94 cx. The problem is that the motor and ecu is redlining at 7700 rpm!? From what I understand jdm b16's are suppose to top out at 8300? I don't have a jdm cluster nor a SI cluster, so I'm having to use a cheap aftermarket gage. Can there be something wrong with the wiring, or did someone **** me over on a ecu? Please help, I'm frustrated!
Old Aug 23, 2003 | 09:35 AM
sinatra's Avatar
Default Re: Ecu red lining at 7,700 rpm??? (SupaFly_Honda)
What is the serial ID number on the ecu. That will tell me alot about what ecu it really is. Could be that the tach is off by approx 1k rpm. That would put you in the 8700rpm range.
Old Aug 23, 2003 | 01:56 PM
SICKSOLSI's Avatar
sounds like you have a p28 ecu or the jdm equivalent
or your tach is off
Old Aug 23, 2003 | 02:29 PM
ScottEK's Avatar
Default Re: Ecu red lining at 7,700 rpm??? (95excoupeMT)
Or it's a B16 PR3 ecu for an automatic.
Old Aug 23, 2003 | 02:49 PM
Default Re: Ecu red lining at 7,700 rpm??? (beta13)
beta13, does automatic and manual have different redline points?
Old Aug 23, 2003 | 02:52 PM
the ecu code reads...37820-pr3-j51 ...its an automatic ecu.
Old Aug 23, 2003 | 03:48 PM
SICKSOLSI's Avatar
you have the right ecu for your motor...im not experienced with auto ecu's but you should do a search and find the shift points of that ecu
Old Aug 23, 2003 | 04:30 PM
blah13's Avatar
If it were an auto ecu you would constantly be throwing a code, are you?
Old Aug 24, 2003 | 11:46 AM
ScottEK's Avatar
Default Re: Ecu red lining at 7,700 rpm??? (blah13)
No it's a myth that all auto ecu's throw codes because I've been driving around with one for 4 months with no code. The redline is at 7600rpm vs. the manual one being at 8200rpm. Adrian from hyperducktuning.com gave me the following information when I had the same problem:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adrian &raquo;</TD></TR><TR><TD CLASS="quote">
in 88-91 ecus (PM6, PR4, PW0, PR3, PM7):
5spd = 000, 001, 002, A00, A01, A10, J00, J001, C01, C00
Auto = J51, J50, A50, A51, 901, A60, C50, C51, X30, A80
So by that chart you do have an automatic ECU. You can change it to a manual ECU but it's pretty difficult. You have to unsolder and move a jumper then solder it back in inside the ecu. If you look inside the ECU find the jumper at spot R68 and move it to R67.
Old Aug 24, 2003 | 11:52 AM
blah13's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beta13 &raquo;</TD></TR><TR><TD CLASS="quote">No it's a myth that all auto ecu's throw codes because I've been driving around with one for 4 months with no code.</TD></TR></TABLE>
I wonder if this doesnt apply to JDM ecus? My auto a6 ecu threw a code when I plugged it up to my ZC before I got the PG7. Hrm
Old Aug 24, 2003 | 02:41 PM
beta13, Thanks for the info. does the ecu run like a regular manual ecu with the removal of the jumper? Is the unsoldering and soldering easy enough for any electricain to do? I ask because I know a few electricians at work.
Old Aug 24, 2003 | 03:11 PM
ScottEK's Avatar
I believe it runs totally the same except for the fuel cut-off. I did the jumper removal the other day but I've done a lot of soldering. The parts you're working with are very very small, it just involves precision soldering.
Old Aug 29, 2003 | 01:04 PM
Beta13, I got some more questions.
I open up the ecu(Pr3) but there is already a jumper at R67. and Spot R68 is empty. Is there another way I can convert this to a manual?
Also, I'm throwing a CEL with this ecu. I haven't trouble shot it, but I'm sure its telling me its a auto ecu.
I ran the car with a P28. The car runs fine and doesnt throw any codes. Help me out yo?
Old Aug 29, 2003 | 04:20 PM
ScottEK's Avatar
Ask Adrian at http://www.hyperducktuning.com he will know.
blasterman87
Nov 30, 2010 03:35 PM
tiresmoke
Feb 26, 2004 10:24 PM
95cx
Apr 25, 2003 08:07 AM
