Check engine light question
Old Aug 22, 2003 | 11:20 PM
StinkyTofu's Avatar
Default Check engine light question
I have a hondata p28 in my car. Before, i had toda b cams and it was tuned for that. Now i have skunk2 stage 1's and i'm still running off the same map. Randomly, i will get a check engine light while driving. But when i turn off my car to check the code, the engine light is gone. What gives?
Old Aug 22, 2003 | 11:28 PM
mmuller's Avatar
Mad Scientist
Default Re: Check engine light question (StinkyTofu)
mine does the same, but its a chipped p 91.is it usually hot when it does that?
Old Aug 23, 2003 | 02:43 AM
StinkyTofu's Avatar
Default Re: Check engine light question (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">mine does the same, but its a chipped p 91.is it usually hot when it does that?</TD></TR></TABLE>
Naw, its not really hot. Like randomly after cruising on the freeway or something. I don't get why it does it? Its not so much the fact that the light is going on, but i'm not sure if something actually bad is going on with my motor.
Old Aug 23, 2003 | 08:55 AM
StinkyTofu's Avatar
anyone know?
Old Aug 23, 2003 | 02:37 PM
StinkyTofu's Avatar
bump
Old Aug 23, 2003 | 03:08 PM
snowseeker's Avatar
Does it throw the light at highway speeds? I have that same thing happen. When I drive along on the highway for about 10 min. my light comes on. But when I shut it off and restart it goes off.
Old Aug 23, 2003 | 03:14 PM
StinkyTofu's Avatar
Default Re: Check engine light question (snowseeker)
Yeah it does that at high way speeds. Or if i'm cruising for a few minutes on a local road. I'm thinking its my primary o2 sensor. Cause when i check for the code, it just flashes once.
Old Aug 23, 2003 | 05:02 PM
F1Spec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StinkyTofu &raquo;</TD></TR><TR><TD CLASS="quote">I ... But when i turn off my car to check the code, the engine light is gone. What gives? </TD></TR></TABLE>
you do not need to turn off the car and turn it back on to check your code.
while the engine is idleing, you can jump the wire and just run the code
code 1-0 is your o2 sensor.
Old Aug 24, 2003 | 06:52 AM
b19coupe's Avatar
Sounds like o2 sensor to me.
Old Aug 24, 2003 | 09:41 AM
snowseeker's Avatar
Default Re: Check engine light question (b19coupe)
o2 sensors are over rated anyhow! LOL
Old Aug 24, 2003 | 09:47 AM
98itR484's Avatar
its the POS chip. My old chip would the exactly the same thing, at least 3 times a day, bought a new chip, never happened again, to this day it has yet to throw a CEL.
Try replacing the chip.
Old Aug 24, 2003 | 12:04 PM
StinkyTofu's Avatar
Default Re: Check engine light question (PacMan ITR)
When you say chip, do you mean the hondata chip? Or the whole p28 ecu?
Old Aug 24, 2003 | 05:18 PM
98itR484's Avatar
the hondata chip.
When i got a new chip put in, the check engine stopped coming on, im hoping it will be the same for you
Old Aug 24, 2003 | 05:47 PM
gsrvx's Avatar
New User
Funny...i was driving on the freeway today...and I got a CEL.
So I pull over and jump the connector...but it flash REALLY quick...not a normal short flash. It was weird.
I just reset my ECU and no code.
I hope it's not the Hondata.
-Rod
Old Aug 24, 2003 | 05:49 PM
gsrvx's Avatar
New User
Default Re: Check engine light question (IBspecRK)
actually...even took a vid....
*RIGHT CLICK SAVE TARGET AS*
http://www.bol.ucla.edu/~rodk/CEL.AVI
what do u guys think? it actually seems slower in the video though. But that can't be a code 1. I've had my o2 sensor wiring throw a code 1 before and it wasn't like this.
Rod
BoRiCuA
Jan 15, 2020 09:58 PM
Teamdiesel
Nov 16, 2007 11:08 AM
90teg
Aug 28, 2003 01:45 PM
VTECVillain
Jan 6, 2002 11:40 AM
