Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Spring rates, how to determine or find.
Old Aug 22, 2003 | 10:39 PM
Driven's Avatar
Default Spring rates, how to determine or find.
I currently have Intrax Lowering Springs on my '90 CRX
Looking to swap out for some Eibach Sportline springs.
I'm aiming to increase the spring rate (as the Intrax springs feel soft).
Anyway to determine the springrate for each? I've search the net and can't find poo...
Old Aug 22, 2003 | 11:35 PM
Tyson's Avatar
Default Re: Spring rates, how to determine or find. (Driven)
you can determine the spring rate by the geometry of the spring. i found a good link that will do the math quickly for you. this only applies to the LINEAR portion of the spring, so take that into account. i would either disregard or try to separate the rings where the coils seems separated at different distances, then add up the spring rates, use the right formula tho, also on that site. take your measurements and calculations for whatever they are worth to you.
http://www.proshocks.com/calcs/coilsprate.htm
heres also a comparative list of various spring rates for mostly an integra. just to give you an idea.
http://php.indiana.edu/~bchang....html
Old Aug 23, 2003 | 12:08 AM
Tyson's Avatar
Default Re: Spring rates, how to determine or find. (Tyson)
i just read about intrax lowering springs. if you just got their "lowering springs" line of springs, they are designed to be exactly the same as OE, or even less with a progressive wind. so no wonder they seem soft. any other spring kit will probably be better. i recommend eibach pro kits. intrax also sells other line of springs called super sport for extra stiffness.
Old Aug 23, 2003 | 12:23 PM
GSpeedR's Avatar
Place weights on top of the spring and determine how much weight (force) is required to compress each spring 1".
patrickstar
Suspension & Brakes
Feb 17, 2009 11:49 PM
Pompiuses
Dec 11, 2008 02:24 PM
Mugenlude
Suspension & Brakes
16
Dec 18, 2007 11:17 AM
NA95d16z6
Suspension & Brakes
29
May 5, 2005 09:40 AM
Superhatch
10
Feb 8, 2002 06:59 PM
