prelude swap for dummies
Old Aug 22, 2003 | 07:26 PM
maxxistheman's Avatar
Default prelude swap for dummies
Hi. I drive a 5-spd 1993 Honda prelude Si DOHC non-vtec. I pretty much destroyed the engine by snapping the timing belt. I want to get an engine swap with a H22a DOHC VTEC motor. I don’t know much about cars, but a few of my friends who know more about cars told me that all I need is the H22a motor, ECU, and wiring harness. But they weren't sure if my existing transmission would work with the H22a motor. Can anyone tell me if my existing transmission will or will not work with the new motor? Also, will a new intake and exhaust be absolutely necessary or will my existing intake and exhaust work fine?
Thanks,
max
Old Aug 22, 2003 | 07:28 PM
4bidden's Avatar
Default Re: prelude swap for dummies (maxxistheman)
Yes, the H23A1 tranny will bolt up fine, but the gear ratios are not optimal for the H22A engine.
Yes, the motors use the same intake.
The cat convertor side of the exhaust has a different flange so it will need minor modification to work. I would suggest just picking up a cheap VTEC test pipe from somewhere.
Old Aug 24, 2003 | 03:26 PM
Default Re: prelude swap for dummies (4bidden)
thanks alot, not having to get a new transmission will save me big time. so essentially all i need is H22 engine, ECU, and wiring harness for a clean swap, right? would you know any websites where i can order the wiring harness for the H22? i plan on getting the engine from nippon-motors.com and from what i understand they only sell engines and the ecu.
thanks
max
Old Aug 24, 2003 | 04:12 PM
PetroGuyX's Avatar
i think skunk2 makes the harness
Old Aug 25, 2003 | 06:27 AM
CHK4TIX's Avatar
Default Re: (PetroGuyX)
you can just use the harness of the h23 and run 3 wires, there is not need to get a new harness. there is also the chance since you have a 93 that your car could already be wired for vtec
Old Aug 27, 2003 | 07:58 AM
Default Re: (CHK4TIX)
does anyone know any online sites where I can get the ECU for the H22??
treyslude
Nov 6, 2012 06:31 AM
mrqwink
Sep 22, 2005 11:31 PM
MRVTEC
Apr 30, 2002 09:11 AM
mattmw88
Nov 1, 2001 09:08 AM
hobo79
Sep 26, 2001 07:36 PM
