Tire Size Question
Old Aug 22, 2003 | 12:41 PM
soloIntegra's Avatar
Default Tire Size Question
Hey Guys,
I have a 2001 Integra. Would a 205/55/15 size-tire fit on my stock 15 inch rims?
Would it cause any damage?
Thanks.
Old Aug 22, 2003 | 01:19 PM
NA gs-R 05 C
Guest
Posts: n/a
Default Re: Tire Size Question (SfGiants)
yea, it'll fit.
Old Aug 22, 2003 | 01:22 PM
dip-set's Avatar
Default Re: Tire Size Question (NA gs-R 05 C)
but get the 205/50/15
Old Aug 22, 2003 | 01:48 PM
pnthr30's Avatar
Default Re: Tire Size Question (teg-your-it)
205/50/15's
Old Aug 22, 2003 | 04:51 PM
Default Re: Tire Size Question (pnthr30)
Would there be a drop in performance with the 205/55/15 series.
Old Aug 22, 2003 | 10:25 PM
thaiphob's Avatar
Nikon!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SfGiants &raquo;</TD></TR><TR><TD CLASS="quote">Would there be a drop in performance with the 205/55/15 series.</TD></TR></TABLE>
you wont really notice a drop. but it sure does look better.
Old Aug 23, 2003 | 03:34 PM
All Motor DB8's Avatar
what kind of tires?... juss wondering ?...okea nevermind ..it will fit
Old Aug 23, 2003 | 04:14 PM
Default Re: Tire Size Question (All Motor Dc 4)
Hey all motor dc 4,
They are Bridgestones RE730. I may be bringing my car back, and going with 205/50/15, like everyone on honda-tech recommends. The Wheel tech says there says it will affect the speedo with that size. I'm wondering, what are the pros and cons of running a 205/50/15 tire size.
Thanks
Old Aug 24, 2003 | 12:48 PM
Bill Hook's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SfGiants &raquo;</TD></TR><TR><TD CLASS="quote">Hey all motor dc 4,
Thanks</TD></TR></TABLE>
I don't think the make RE730s in 205/50-15, but the comparable Yokohama AVS ES100 comes in 205/50-15, which is less than 0.5 % diff. than OEM tire diameter, per Yoko's spec sheet.
The advantages would be better handling and braking since more rubber meets the road. The DAs are that the steering feel and turn-in may be slightly less. I'd recommend boosting the PSI by 3lbs. over stock, front and rear, to help stiffen things up. You might go more, but it's a trade-off between ride and handling.
Old Aug 24, 2003 | 05:12 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Definitely go with 205/50-15. I've seen 205/55-15 on stock GS-R wheels and they look like balloon tires.
Old Aug 24, 2003 | 05:31 PM
. o 69 o .'s Avatar
Default Re: Tire Size Question (PatrickGSR94)
i have the yokohama ES100's..... They kick ***, i have never had any problems with them
90teg
15
Nov 3, 2005 07:25 AM
civic702
Feb 21, 2005 01:39 PM
v0lcom27
10
Feb 15, 2005 09:50 AM
NickEG
Apr 25, 2004 09:41 AM
kinvid22
Mar 30, 2004 12:06 AM
