What kind of cams are you running for your turbo setup
Old Aug 22, 2003 | 12:36 PM
sleepyhamsterlx's Avatar
Default What kind of cams are you running for your turbo setup
just want to see what everyone here is running.
Old Aug 22, 2003 | 01:19 PM
spoolinlude's Avatar
I live under a rock
Default Re: What kind of cams are you running for your turbo setup (eriklxsd)
Stock SI cams,.... once you've got so much boost, the turbo doesn't care and just shoves air down there!!
Old Aug 22, 2003 | 01:20 PM
ProEater's Avatar
Default Re: What kind of cams are you running for your turbo setup (spoolinlude)
gsr cams
Old Aug 22, 2003 | 01:24 PM
01ITR#700's Avatar
Default Re: What kind of cams are you running for your turbo setup (ProEater)
Stock.
Old Aug 22, 2003 | 01:32 PM
FredoSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProEater &raquo;</TD></TR><TR><TD CLASS="quote">gsr cams</TD></TR></TABLE>
w/ STR cam gears
Old Aug 22, 2003 | 01:46 PM
System-7's Avatar
in all actuality you will yield a better power through out the entie RPM range with turbo cams. See the SI and GSR cams work well but they also let unused boost escape because of overlap.
autoEXturbo's Avatar
type r cams in a gsr head.
Old Aug 22, 2003 | 03:03 PM
Turbocivic94's Avatar
stock b16a
Old Aug 22, 2003 | 05:14 PM
NyQuiL's Avatar
webber
242 intake
248 exhaust
Old Aug 22, 2003 | 05:46 PM
T4eg's Avatar
Default Re: (NyQuiL)
stock gsr cams with STR cam gears
Old Aug 22, 2003 | 06:41 PM
hybrid901's Avatar
Default Re: (BlueHatch00)
stock gsr
Old Aug 22, 2003 | 06:48 PM
viprcr1's Avatar
Default Re: What kind of cams are you running for your turbo setup (autoEXturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by autoEXturbo &raquo;</TD></TR><TR><TD CLASS="quote">type r cams in a gsr head.</TD></TR></TABLE>
why are you using type r cams. dont they have a lot of overlap because it is an al motor cam.
Old Aug 22, 2003 | 08:39 PM
slowtealgsx's Avatar
Default Re: What kind of cams are you running for your turbo setup (Mgnlxsd)
id say go with type r cams brand new from the factory for 350 and i believe it was AUTOEXTURBO that got close to 30hp just from the cams alone.
Old Aug 22, 2003 | 08:52 PM
TurboCX's Avatar
Default Re: What kind of cams are you running for your turbo setup (slowtealgsx)
GSR cams.
Old Aug 22, 2003 | 09:41 PM
Hispeed's Avatar
crower 401t
Old Aug 22, 2003 | 10:41 PM
st00pid's Avatar
Default Re: (GSRev)
Old School JG 1001s = best LS/turbo cams evAr!!!
shami
Old Aug 23, 2003 | 09:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowtealgsx &raquo;</TD></TR><TR><TD CLASS="quote">id say go with type r cams brand new from the factory for 350 and i believe it was AUTOEXTURBO that got close to 30hp just from the cams alone.</TD></TR></TABLE>
Yep, made about 40whp more than the gsr cams did.
Old Aug 23, 2003 | 04:49 PM
I live under a rock
Default Re: (System-7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by System-7 &raquo;</TD></TR><TR><TD CLASS="quote">in all actuality you will yield a better power through out the entie RPM range with turbo cams. See the SI and GSR cams work well but they also let unused boost escape because of overlap. </TD></TR></TABLE>
Then explain why all the pro guys still use Stock cams?
Old Aug 24, 2003 | 06:31 PM
System-7's Avatar
Default Re: (spoolinlude)
they still use them because they do their job well. but dynos show more power with turbo cams. I don't know that all the pro guys use stock cams, that may be an incorrect asumption.
Old Aug 24, 2003 | 06:37 PM
System-7's Avatar
just thought of this, most of those guys have head work done, could explain why they use stock cams.
i'm assuming with a port and polish, different valves and springs that may work.
Old Aug 24, 2003 | 06:42 PM
DIRep972's Avatar
Smarter than you
Default Re: (st00pid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by st00pid &raquo;</TD></TR><TR><TD CLASS="quote">Old School JG 1001s = best LS/turbo cams evAr!!!
shami</TD></TR></TABLE>
I Hope so. might be giving these things a shot.
Old Aug 26, 2003 | 08:01 AM
rb08's Avatar
i personally know of someone who got 740 hp at the wheels with a stock (unported) gsr head, and type r cams with a b16 block. im not gonna mention any names. they know who they are.
Old Aug 26, 2003 | 12:36 PM
COOKIEPUSS's Avatar
Very Impressive, this was the only change to get this much HP? If so I'm very impressed.
Old Aug 26, 2003 | 12:57 PM
Default Re: What kind of cams are you running for your turbo setup (COOKIEPUSS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by COOKIEPUSS &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, that was all that was changed. I was very impressed.
Old Aug 26, 2003 | 01:20 PM
prostreetonline's Avatar
Our customers have had good luck with stock cams.
nek9
Mar 19, 2007 06:56 AM
GWInquisitor14
Sep 7, 2005 06:25 AM
highboostb18c1
Jun 21, 2004 03:58 AM
rocket256
Dec 25, 2003 07:30 PM
MysteriousGSR
Apr 15, 2002 06:47 PM
