Toe question
Old Aug 22, 2003 | 11:38 AM
tub_sephiroth's Avatar
Default Toe question
Will changing my wheels from 205/40/17 to 205/50/15 change my toe? or vice versa? I don't want to get another alignment.
Old Aug 22, 2003 | 12:20 PM
Doctor CorteZ's Avatar
Default Re: Toe question (tub_sephiroth)
you do know what toe is , correct ?
Old Aug 22, 2003 | 01:34 PM
GSpeedR's Avatar
Your tie will not change unless the hub position changes. It changes most drastically by the tie-rod length affecting its side-to-sid position, but also by changes in vertical position (based upon location of tie-rod and axle). So, if the overall circumfrence of these new tires is the same as the previous set, then the hub position will not change and hence the toe will not change.
Do a search to get a better explanation of what toe is.
Old Aug 22, 2003 | 05:02 PM
Of course I know what toe is. I did do a search. Isn't that suppose to be the first thing you do before you post a new topic?
Old Aug 22, 2003 | 08:58 PM
GSpeedR's Avatar
Then you know what toe is and you got your answer, what more could you wish for?
Old Aug 22, 2003 | 09:35 PM
Default Re: Toe question (GSpeedR)
If you do a search and find out the answer to my question then please post the link to me since I'm too lazy to search and you're not. Thank you.
Old Aug 23, 2003 | 06:55 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tub_sephiroth &raquo;</TD></TR><TR><TD CLASS="quote">Will changing my wheels from 205/40/17 to 205/50/15 change my toe? </TD></TR></TABLE>
No.
RoyBoy808
Hawaii & Asia-Pacific
Mar 3, 2008 05:59 AM
yjischoking
Oct 8, 2005 05:09 PM
DsCivicEx
Dec 4, 2003 02:15 PM
KMK1605
Nov 4, 2003 06:07 AM
Big Phat R
Jun 28, 2001 02:11 PM
