Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
alignment question
Old Oct 8, 2005 | 01:23 PM
yjischoking's Avatar
Default alignment question
sorry if this is a repost but I did try to search and didn't find anything relevant. I just had a quick question about alignment for auto-xing. My alignment is off (it pulls to the right a fair amount).
My question is whether or not this will make a significant difference in my turning speed/ability. Also, is the effect (if tehre is one) amplified by rain (as predicted for tomorrow morning). So essentially, should I run my car tomorrow or just sit this one out?
thanks in advance!
o and this is on a 92 non-posi camaro if that matters any
Old Oct 8, 2005 | 02:10 PM
Default Re: alignment question (yjischoking)
bumpity bump
Old Oct 8, 2005 | 02:36 PM
.RJ's Avatar
.RJ
no bumping, thanks be patient, the forum moves slow on weekends
Old Oct 8, 2005 | 05:09 PM
ryer_t's Avatar
Your question is to broad to give you a real answer. There are two many things that could pull your car. Not just your alignment. Caster can cause a pull. Camber can cause a pull. Tires can cause a pull. Brakes can cause a pull. But yes your aligment being off will effect your turning to speed/ability. You should swap the front tires and make sure its not tire pull. I would start there.
95ejjj
Suspension & Brakes
Apr 1, 2010 01:59 PM
dookieface
Aug 14, 2004 10:44 PM
HatchBox
Sep 1, 2003 08:51 PM
scoobyghost
Aug 17, 2003 07:28 AM
