hood problems
i know that this is in the wrong area, but my CL is messed up and i dont know howto get the hood up without using the pull on the inside. can anyone help.
did the plastic hood latch break?? you can usually use some pliers to pull the cable if that is the case....if you can get the car in the air, you can probably do it from underneath the car behind the bumper.
SMASH ****! DIE HOOD!
