Poor spark after swap.
Old Aug 22, 2003 | 10:01 AM
Hondasaurs's Avatar
Default Poor spark after swap.
I just did a SOHC ZC swap in a 92 civic. The engine ran for a few minutes then cut out. I checked the spark and it's very weak. What could cause this and what can I do to corrrect it. I'm going to take the coil out and get it tested too.
Old Aug 22, 2003 | 12:39 PM
SpyderZEX's Avatar
Default Re: Poor spark after swap. (Hondasaurs)
Did you replace the Dizzy cap, rotor, and spark plug wires when you did the swap?
Old Aug 22, 2003 | 01:46 PM
PHiZ's Avatar
Default Re: Poor spark after swap. (SpyderZEX)
Well, grounds, but if you do conversion harness and swaps, you already know that.
I was working with a guy, and he didn't have any grounds, he was going to install them afterwards... Well the motor sucked all the strray electrons out of the the engine block, and then wouldn't run anymore... Remember, motor mounts are RUBBER, hahah.
-PHiZ
frank dalia
10
Jul 27, 2009 11:28 AM
AZNracerx1989
Aug 8, 2006 04:08 PM
whiterex
Feb 24, 2005 09:02 AM
[626]95-GSR
Feb 14, 2002 03:11 PM
