1/4 mile times with turbo?
Check the sig. the 1/4 mile and 60'ft. times are not the greatest but the mph is good for high 12's, so i've been told. I forgot to add that this is a sohc greddy turbo kit and the car was untuned on *** street tires.
Slight hijacking here, but did you modify the greddy SOHC manifold or did you use another one? If you modified it, how much work was involved? If I eventually blow my ZC up, I may go to a B series and try to use my greddy kit.
Thanks!
Thanks!
I kept the sohc mani and just ported it out with a dremel. I do plan on putting the dohc greddy turbo on the car though. Unless I run a 12 sec. 1/4 mile with this set up. I think it should be no problem now that it's tuned and I have slicks. FYI it made 205whp and 200 lb. ft. of torque at 9 psi. But I know the mani. is choking it out.
my b16 setup with turbo ran 13.3 at 115 with 225 hp to the wheels 8 psi, street tires only. my friends hatch ran 12.4 at 111 with drag radials, not sure of his hp though, I no longer have this setup but and have not dynoed my car nor ran it with the new setup.
SilverS
Nov 6, 2001 08:45 PM
