Straight power yo fuel pump?
12 volts is 12 volts..........
No, but why would you want to?
as long as its a good power source, it will be fine. You want more flow, get a bigger pump.
Rob
Rob
use a relay inbetween the battery and pump, and turn the relay on with the ignition.
The only way you would get more flow, is if the stock wiring is not able to provide full amperage to the pump under full boost/fuel pressure/flow.
boost16awd
10
May 19, 2017 10:21 AM
jvans04
Jul 24, 2005 04:49 PM
