Is it possible to turbo d15 mini me?
Old Aug 21, 2003 | 11:37 PM
AVXHATCH's Avatar
Default Is it possible to turbo d15 mini me?
I searched but can not find anything about a mini me d15 turbo (d16z6 head) is it possible to run about 5-6 psi safely on this set up?? because i was told the head will higher compresion. thanks
Old Aug 21, 2003 | 11:59 PM
nigel's Avatar
you can do this setup, but its a little pointless because the dx blocks are so weak. you might as well get whole d16z6 and turbo it.
Old Aug 22, 2003 | 12:08 AM
oscarmayer's Avatar
Default Re: (nigel)
it's not the block that is weak. it's the cranks that blow.
our are better off getting a d16 (16 valve type) and go from there
Old Aug 22, 2003 | 12:27 AM
AVXHATCH's Avatar
Default Re: (oscarmayer)
This is my first tubo engine so i wanted to turbo something that i know i wouldnt care about if blows haha, in the future i plan on turboing a B series. If im on about 5 psi on the d15, and i do not drive it to hard, will it last atleast 20k miles?
Old Aug 22, 2003 | 02:39 AM
The Brown Kid's Avatar
Default Re: (AVXHATCH)
Mini Me d15/d16z6 head
Rods are pretty weak as well. I ran about 7 daily with 440dss and a fpr.
When it blew im not sure how much i was boosting
Old Aug 22, 2003 | 06:25 AM
rioninja's Avatar
Default Re: Is it possible to turbo d15 mini me? (AVXHATCH)
5-6psi is nothing as long as its properly fueled.
have fun
Old Aug 22, 2003 | 06:59 AM
hoya_10fintec's Avatar
Default Re: (The Brown Kid)
something went wrong there..
as long as you get the good fuel management/tuned, you should be fine but I wouldn't go more than 7psi..
Old Aug 22, 2003 | 08:35 AM
mrod006's Avatar
Default Re: (hoya_10fintec)
i would say to keep the boost at 5. make sure that you get it tuned or you will have big problems.
Old Aug 22, 2003 | 08:54 AM
AbaZ's Avatar
I've had 2 mini-me turbos, both came out real good, 1 a6 minime and a b2 minime. Just go easy on your timing, and make sure shes tuned good.
Jeff
Old Aug 22, 2003 | 09:06 AM
turbo_ef9's Avatar
Default Re: Is it possible to turbo d15 mini me? (AbaZ)
i have a mini me as my backup motor right now.. boosting 10psi with afc hack on a b-series 18g turbo.. colder plugs, retarded timing.. so far so good.. been going about a month and a half now.. probaly already has about 4k put on it racing
Old Aug 22, 2003 | 09:09 AM
twkdCD595's Avatar
Default Re: Is it possible to turbo d15 mini me? (eli_vang)
rods are the weak point, along with the rings lands.
Old Aug 22, 2003 | 11:23 AM
AVXHATCH's Avatar
Default Re: Is it possible to turbo d15 mini me? (twkdCD595)
thanks for all the replys What type or fuel management do you guys suggest? and what size injectors? The turbo i thinking of going with is a conquest turbo, becuse i heard the stock psi setting would be around 5-6 psi is this turbo good for low boost? thanks agin
Old Aug 22, 2003 | 07:36 PM
AVXHATCH's Avatar
does any one know what type of fuel management would be good for this set up?
Old Aug 22, 2003 | 08:15 PM
Slammd Sol's Avatar
I have been running a D15b7 @ 5-6 psi for like 5 months now.. Still running strong.. I am using DSM 450s w/ AFC for fuel.
Old Aug 22, 2003 | 08:18 PM
slowtealgsx's Avatar
you can turbo anything just push it untill it blows up who cares.
Miramax
Jul 4, 2015 01:22 AM
Singlefury
18
Feb 16, 2006 07:33 AM
