what is this thing (button switch conected to clutch pedal.89 crx hf
Old Aug 21, 2003 | 09:34 PM
crx1856's Avatar
Default what is this thing (button switch conected to clutch pedal.89 crx hf
what is the switch conected to the clutch pedal that is pushed in when the clutch is depressed. i was wondering if i can replace that with my hondata clutch switch. the button switch there now has a black and green wire to the plug for it.
Old Aug 21, 2003 | 11:18 PM
RCautoworks's Avatar
Default Re: what is this thing (button switch conected to clutch pedal.89 crx hf (crx1856)
Its the clutch saftey switch, if you go here hondata actually shows it being used.
http://www.hondata.com/featureslaunch.html
Old Aug 22, 2003 | 06:37 AM
Guam_CiviC619's Avatar
Default Re: what is this thing (90blackcrx)
I almost nut myself when I "sat in the passenger seat" of that 10 sec car!!!!
Old Aug 22, 2003 | 07:55 AM
crx1856's Avatar
Default Re: what is this thing (Guam_CiviC619)
i'm not talking about the hondata clutch switch, im talking about the switch that comes in my car stock. i just want to know what it is and if i can take it out and use the mounting bracket for my hondata clutch switch.
Old Aug 22, 2003 | 10:44 AM
crx1856's Avatar
Default Re: what is this thing (crx1856)
anyone?
Old Aug 22, 2003 | 11:48 AM
You can take it out, but you will need to cut the wires and solder them together or else your car won't start. But if you do this, you will not need to press the clutch in anymore when you start it.
ham
Oct 5, 2005 02:46 PM
*Boostwerks*
Nov 18, 2004 09:42 AM
crx1856
Aug 5, 2003 11:35 PM
Scott - 93HB Si
Aug 9, 2002 10:08 AM
