Spoon drain plugs Q
Sorrry i did search but didnt find anything...the spoon drain plugs set comes with two plugs on with a short magnet and one with a long magnet....my question is which one is oil pan and which is the tranny fluid...thanks...and will the long magnet work in both?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRPaul »</TD></TR><TR><TD CLASS="quote">will the long magnet work in both?</TD></TR></TABLE>
the short will work in both but the long won't fit in the tranny
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all stock »</TD></TR><TR><TD CLASS="quote">spoon's magnetic drain plugs are stronger than the cheap ones.
slightly stronger, but still - stronger nonetheless</TD></TR></TABLE>
Really? What is the difference in ultimate tensile strength between the Spoon plug and say, a Grade 8 hardened plug from my local hardware supplier?
Also please share why either the engine oil or tranny drain plugs need to be "strong" since they bear no load other than the minimal torque required to maintain a seal through which low pressure liquid cannot pass?
Modified by sackdz at 10:22 AM 8/22/2003
Maybe he is talking about magnet strength???
Personaly, I think the tranny one is a waste since there is a magnet allready in there. As for the oil pan one, just got to autozone and pick one up for 4 bucks.
Well if you want a set, buy this guys:
https://honda-tech.com/zerothread?id=599120
Won't someone do a "Great Drainplug Test"?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny »</TD></TR><TR><TD CLASS="quote">Maybe he is talking about magnet strength???
Personaly, I think the tranny one is a waste since there is a magnet allready in there. As for the oil pan one, just got to autozone and pick one up for 4 bucks.</TD></TR></TABLE>
w3rd!
-Bryan-
w3rd!
-Bryan-
Well i have both the tranny plug and the oil plug on my R. Since I have drained the tranny oil at least 4 times in the last year... I have yet to find and particles on the plug magnet.... however, when I had the tranny open and was cleaning out the case I did notice fine particles stuck to the magent which come mounted in the tranny.
As for the oil plug, I do notice very, very fine particles attached to the magnet when doing oil changes... so I know the magnet concept works.... (Will those, fine, fine particles cause damage to the engine, I dont know)
Heres my old thread before I was kicked.
https://honda-tech.com/zerothread?id=292405
Bunch of shavings in the oil.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackdz »</TD></TR><TR><TD CLASS="quote">
Modified by sackdz at 10:22 AM 8/22/2003</TD></TR></TABLE>
I meant magnetic strength. I did a crude test.
I was holding up large soup cans with the spoon drain plug. my roomate's kragen magnetic drain plug couldn't do that.
yes they are. the mags you need to get are called neo... **** i forgot.
anyways that mag i have on there can hold around 10lb. i htink its
strong enough since the magnetic bolt in the tranny is barely able to
hold only 1lb. i know my 10/l mag is stong enough.
esoterEK..
10
Jul 29, 2002 08:45 PM
