How do you remove the stereo from the dash on a 99 teg
Old Aug 21, 2003 | 08:19 PM
IntegraLova's Avatar
Default How do you remove the stereo from the dash on a 99 teg
i have to get the cd player out to get the serial number to unlock the damn thing. but i cant figure out how to get to it. the mid panel is being a bitch to get off. please someone help
Old Aug 21, 2003 | 08:36 PM
integra72's Avatar
Default Re: How do you remove the stereo from the dash on a 99 teg (IntegraLova)
on the passenger side lok up under the dash with a light and you should see 2 8mm bolts you haveto take them out then the radio comes out the front
good luck
Old Aug 21, 2003 | 08:49 PM
91TegLS's Avatar
follow integra72's directions, just a warning though, it's a pain in the *****, just pulled the radio outta my 91 a few days back.
Good luck!
Old Aug 21, 2003 | 09:27 PM
Default Re: (91TegLS)
do you not have to take the console out or anything for this?
Old Aug 21, 2003 | 10:03 PM
JMod's Avatar
Default Re: (IntegraLova)
you can, but you don't have to. I ended up having to because i couldn't get the bolts undone by sticking my hand up through the wires in the back.
Old Aug 21, 2003 | 10:10 PM
integra72's Avatar
no you don't have to take out the center console
you can also call your local circuit city and for about 20.00 they will pull it out for you in about 3 minutes
Old Nov 7, 2003 | 06:02 PM
10K2HVN's Avatar
Default Re: How do you remove the stereo from the dash on a 99 teg (integra72)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra72 &raquo;</TD></TR><TR><TD CLASS="quote">on the passenger side lok up under the dash with a light and you should see 2 8mm bolts you haveto take them out then the radio comes out the front
good luck </TD></TR></TABLE>
this is best!,
do not remove the bolts all the way! just losen them then you can pull out the deck. after the deck is out retighten them so you know where the are..or you can take them out if you wanna save some weight (2~3 bolts..?)
imadigitalgod
Audio / Security / Video
Feb 12, 2009 06:18 PM
blazeaglory
Feb 12, 2007 03:14 PM
masteroflife67
Sep 29, 2005 03:27 PM
SlowLSTeg
Jun 11, 2002 01:26 PM
SlowLSTeg
Jun 11, 2002 07:02 AM
