How do you tell if a JDM B18C engine has LSD?
Old Aug 21, 2003 | 07:38 PM
Hapa88's Avatar
Default How do you tell if a JDM B18C engine has LSD?
I was wondering if there was any way to tell from the outside of the engine if a B18C with S80 tranny has LSD? Like does a serial number say? Or is it supposed to be stamped? Or does the S80 tranny inheriently have LSD? Also is there any other way to do so without taking the engine apart? Any help would be great. .
Old Aug 21, 2003 | 07:47 PM
Lord Helmet's Avatar
Default Re: How do you tell if a JDM B18C engine has LSD? (Hapa88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hapa88 &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering if there was any way to tell from the outside of the engine if a B18C with S80 tranny has LSD? Like does a serial number say? Or is it supposed to be stamped? Or does the S80 tranny inheriently have LSD? Also is there any other way to do so without taking the engine apart? Any help would be great. . </TD></TR></TABLE>
no you don't take the engine apart but you do have to pull the axles out to look thru the hole to see. oem lsd stamps thru years of use will rub off or fade off so the best and easiest way is looking thru the tranny. if you see a bar in the diff then it's a peg leg(non-lsd) tranny. but if you see right thru the tranny without any obstructions then it's a lsd tranny.
Old Aug 21, 2003 | 08:21 PM
92VtecTeggy's Avatar
Default Re: How do you tell if a JDM B18C engine has LSD? (sleeperciv)
i thought it was the other way around? if there was a bar going through the diff. that means it's lsd. but if it doesnt, then its not.
Old Aug 21, 2003 | 08:27 PM
94TurboGSR's Avatar
It will most likely have a stamp on it. Look for the stamp.. if you have it, you have one.. if not... you might still have one if it rubbed off.
Old Aug 21, 2003 | 08:46 PM
threatcon13's Avatar
New User
Default Re: How do you tell if a JDM B18C engine has LSD? (92VtecTeggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92VtecTeggy &raquo;</TD></TR><TR><TD CLASS="quote">i thought it was the other way around? if there was a bar going through the diff. that means it's lsd. but if it doesnt, then its not.</TD></TR></TABLE> no...what he said was correct.
Old Aug 21, 2003 | 09:12 PM
Hapa88's Avatar
Default Re: How do you tell if a JDM B18C engine has LSD? (TealTurbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TealTurbo &raquo;</TD></TR><TR><TD CLASS="quote">It will most likely have a stamp on it. Look for the stamp.. if you have it, you have one.. if not... you might still have one if it rubbed off. </TD></TR></TABLE>
Only stamp I can see is "V4D" on the tranny. Thats is. . . anyone know what this means?
Old Aug 23, 2003 | 02:23 PM
Hapa88's Avatar
anyone know what "V4D" stamped on the Tranny means?
Old Aug 23, 2003 | 02:24 PM
B16OnTop's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hapa88 &raquo;</TD></TR><TR><TD CLASS="quote">anyone know what "V4D" stamped on the Tranny means?</TD></TR></TABLE>
it means that its AWD
Old Aug 23, 2003 | 09:24 PM
mugenracer's Avatar
My JDM integra Si has a Y80 tranny and LSD but there are no markings/stamps anywhere on it. as far as i know they didnt start stamping/marking LSD trannies till after 1996 (my car is 1994)
Old Aug 24, 2003 | 12:28 AM
UR2FAT's Avatar
Default Re: (mugenracer)
I have a JDM Si DC2 aswell, I also have an LSD g/b, and I also have no markings on the gearbox. Mine is a '93 model.
Old Aug 24, 2003 | 10:46 AM
RedStarGsr's Avatar
gotta love jdm cable trannies!
Old Aug 24, 2003 | 10:49 AM
JDMHN8's Avatar
Default Re: (RedStarGsr)
My Y1 has LSD stamped into the metal and my buddy's Y21 has a black ink stamp that says LSD. If you can see through the diff, then you've got an LSD.
tysonboy
Jul 15, 2009 01:17 PM
Running925
Sep 12, 2007 06:37 PM
gursh d
Jul 24, 2007 06:56 AM
SCOOBYKILLER15
Dec 8, 2006 05:42 AM
MaxSterling
Jun 3, 2003 06:51 AM
