How many of you have had turbo's fail due to a poorly designed drain line?
Old Aug 21, 2003 | 01:23 PM
*Boostwerks*'s Avatar
Default How many of you have had turbo's fail due to a poorly designed drain line?
Just wondering.
If you have pics of the suspected drain line, please post them!
Thanks
Bryson
Old Aug 21, 2003 | 02:06 PM
mos's Avatar
mos
Default Re: How many of you have had turbo's fail due to a poorly designed drain line? (Bryson)
How many of us.. err how many of them will admit it!?
Old Aug 21, 2003 | 03:04 PM
krazy's Avatar
Default Re: How many of you have had turbo's fail due to a poorly designed drain line? (mos)
bump! i wanna see!
krazy
Old Aug 21, 2003 | 04:11 PM
tek_civic's Avatar
Default Re: How many of you have had turbo's fail due to a poorly designed drain line? (krazy)
im sure that my drain line is horrible but it hasn't failed yet! mine is watercooled so i don't get as much oil flow, and its not AS dependant on oil as sau a oil cooled t3.
hehe post # 1000
Old Aug 21, 2003 | 07:15 PM
Sinner's Avatar
i've had mine screw up the seals, the drain line was pinched so it sprayed oil out the seals, but once I fixed it, it stoped
Nick
Old Aug 21, 2003 | 11:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mos &raquo;</TD></TR><TR><TD CLASS="quote">How many of us.. err how many of them will admit it!?</TD></TR></TABLE>
Exactly one of the problems I've found.
Another problem is that I see many people on this board look down upon other drain setup's saying "don't use 90deg fittings", "the downward slope isn't steep enough"...ect...However, I see very few people end up with a blown turbo as the result...?
This is my opinion (based on evidence that I've seen)...
If the outlet of the turbo is higher than the inlet on the pan you will be fine (assuming the line is big enough (10an), and the entire drain line is lower than the turbo's outlet).
Old Aug 22, 2003 | 07:45 AM
luckypon7's Avatar
i have no pics but my turbo seal leaked because my return line had a kink.
Old Aug 22, 2003 | 08:54 AM
Tinker219's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">
ya, 3 turbos later, I found this out. They may actuallly still be good, but they were tired anyway, and my 60-1 came back, so ya w00 w00. half inch ID isnt big enough on H series engines...
hondaeg8
May 23, 2006 11:53 AM
AIRIC
May 22, 2006 04:54 PM
88crxhfb16
Jun 27, 2005 08:53 AM
civicek00
May 31, 2005 09:38 AM
D A 9
Jul 27, 2003 05:16 AM
