Is it my alignment or is it worse?
Old Aug 21, 2003 | 11:26 AM
Nice_Dc2r's Avatar
Default Is it my alignment or is it worse?
For about a month my car was sitting on a flat tire(front left). now that i changed changed the tire the car pulls to the left but what weird is that the wheel is perfectly aligned with the direction i am turning. for instance when i am going straight the wheel is perfectly centered but if i let go it will pull pretty hard to the left. Thanks in advance
Old Aug 21, 2003 | 12:56 PM
JimBlake's Avatar
Default Re: Is it my alignment or is it worse? (nice_eg)
So you replaced the tire, now your front tires aren't the same. One's new & one's partly worn down. Swap your tires side-to-side & see if it pulls the opposite way.
Old Aug 21, 2003 | 07:52 PM
EG TYPE-R's Avatar
Default Re: Is it my alignment or is it worse? (JimBlake)
defenitely sounds lika a tire pull problem
Old Aug 22, 2003 | 10:19 AM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
just balance your tires.....may need to replace front right one to balance everything out....then you should be coo
Old Aug 22, 2003 | 12:51 PM
Nice_Dc2r's Avatar
Default Re: (dgonzals)
both front tires brand new toyo proxess
Old Aug 22, 2003 | 03:44 PM
dgonzals's Avatar
it still does it? hey josh, its grandpa foo......
Old Aug 25, 2003 | 03:26 AM
JimBlake's Avatar
Default Re: (nice_eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nice_eg &raquo;</TD></TR><TR><TD CLASS="quote">both front tires brand new toyo proxess </TD></TR></TABLE>Do your rear tires match each other?
Otherwise it sure sounds like an alignment problem. But I don't understand how it would be related to sitting on a flat tire...
zx2gotboost
Sep 28, 2010 09:16 AM
ej6hatchie
Apr 14, 2008 04:22 PM
Evolution-93-Ex
Feb 17, 2008 09:34 AM
TOO MUCH TORQUE
Feb 8, 2007 11:57 PM
ilu
15
Jun 1, 2006 09:16 PM
