tire mounting...do they have to be balanced?
i need new tires, but my roommate insists that they have to be balanced, so instead of just getting them mounted and slapping them on i have to have a shop do it so they can be balanced on a machine. is this true?
Re: tire mounting...do they have to be balanced? (ilu)
Its not that much to get the tires mounted and balanced. normally comes as a package deal. like $10 per tire cheapest and $20 for the most.
Re: tire mounting...do they have to be balanced? (onefast93sol)
You dont HAVE to get them balanced.
I just wont be suprised when I see a thread "My steering wheel shakes, HELP!?!?!" in the next few days.
Re: tire mounting...do they have to be balanced? (Jedi_Sol)
what will happen when you don't balance your tires, at the right speed your wheel will make your whole car shake. usually it's not as annoying driving in town as it is on the highways...
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilu »</TD></TR><TR><TD CLASS="quote">i need new tires, but my roommate insists that they have to be balanced, so instead of just getting them mounted and slapping them on i have to have a shop do it so they can be balanced on a machine. is this true?</TD></TR></TABLE>
So you were going to mount them yourself? You have a tire machine? Or were you going to use another one of the backwoods moron tricks that so many of the worthless people on this forum use?
No. All balancing does is overinflate the tires. There's no need for it. While your at it, drive around with half the recommended tire pressure
1 Post
Re: tire mounting...do they have to be balanced? (black_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_EM1 »</TD></TR><TR><TD CLASS="quote">No. All balancing does is overinflate the tires. There's no need for it. While your at it, drive around with half the recommended tire pressure </TD></TR></TABLE>
Don't forget to rotate your valve caps.
Re: tire mounting...do they have to be balanced? (JDM-97CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX »</TD></TR><TR><TD CLASS="quote">
So you were going to mount them yourself? You have a tire machine? Or were you going to use another one of the backwoods moron tricks that so many of the worthless people on this forum use? </TD></TR></TABLE>
you dont have to have a tire machine. there are tools made to specificly for doing so. Do you think there have always been tire machines? doing this on a car isnt **** try changeing tires on a semi on the side of the road by hand.
Yes you tires have to be balanced unless you want the feeling of your car vibrating apart when you go down the highway!!
Re: tire mounting...do they have to be balanced? (tatmark1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tatmark1 »</TD></TR><TR><TD CLASS="quote">
you dont have to have a tire machine. there are tools made to specificly for doing so. Do you think there have always been tire machines? doing this on a car isnt **** try changeing tires on a semi on the side of the road by hand.</TD></TR></TABLE>
Did you want a medal or something? Balancing is cheap and effective. The initial post was asinine anyways, and I doubt he even knows what you're talking about
i didnt say not to balance them. i would balance them. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_EM1 »</TD></TR><TR><TD CLASS="quote">
Did you want a medal or something? Balancing is cheap and effective. The initial post was asinine anyways, and I doubt he even knows what you're talking about</TD></TR></TABLE>
Don't forget to rotate your valve caps.</TD></TR></TABLE>
Don't forget to re-lube your muffler bearings
just pay the little bit have them mounted and balanced it will save you a lot of headache and having any problems with vibration
no i was going to have them professionally mounted, i was asking if they had to be balanced on my car.
but apparently this question has been answered.
