What are some signs of worn out wheel bearings
Old Aug 21, 2003 | 11:21 AM
Nice_Dc2r's Avatar
Default What are some signs of worn out wheel bearings
Old Aug 21, 2003 | 11:45 AM
sambam27's Avatar
Default Re: What are some signs of worn out wheel bearings (nice_eg)
squeeking sounds and could probably feel a little grinding on the tire.
Old Aug 21, 2003 | 12:06 PM
Daemione's Avatar
Default Re: What are some signs of worn out wheel bearings (PreLudexSi)
I don't know about squeaking or grinding, neither of the two bearings that have gone bad on me made those noises. Maybe if it goes on so long that it starts to scrape into the spindle or something . . . .
But the bearing is usually a thumping or knocking from the wheel area that increases in frequency the faster you go - turns into a loud roar at higher speeds.
And it'll be noise isolated to one side or the other - i.e. if it's a bad right bearing, any hard right turn will make the noise go away as weight is removed from that corner. A hard left turn might make the noise louder.
And when it's jacked up, you'll be able to shift the entire wheel back & forth a little bit on it's bearing - it'll be "wobbly".
Old Aug 21, 2003 | 12:42 PM
sambam27's Avatar
yea..i dont kno tho. it just happened me to, but it could be different.
Old Aug 21, 2003 | 01:10 PM
JimBlake's Avatar
Default Re: (PreLudexSi)
They can go bad by getting loose. Then the wheel can wobble, you can grab the tire & 12oclock & push/pull to check if it's loose. But the upper ball joint could be loose too. Gotta look to see where the looseness is located.
Bearings can also go bad by getting tight. I haven't had one go on a Honda, but on a '89 Saab it sounded just like a knobby mud tire. When I took off the steering knuckle it was difficult to spin the bearing. Felt like it had sand in it but it was never loose...
Old Aug 21, 2003 | 01:11 PM
svtec's Avatar
L D E S
Default Re: (JimBlake)
when it starts to sound like you have swampers on your car around smooth, sloping corners.
Phil_46
Jun 11, 2013 09:16 PM
Jamezvtec
Honda Civic (2001 - 2005)
Jun 11, 2009 04:43 PM
Mr_Moos
Jul 10, 2006 02:50 PM
frostcivic
May 11, 2006 02:23 AM
ricekiller1
May 2, 2006 08:39 AM
