Integra window rattles when i close door...
Old Aug 21, 2003 | 10:38 AM
SilverDc2's Avatar
Default Integra window rattles when i close door...
for the past couple of monthes my windows in the front rattle if they are not close all the way up. is there anyway i can get them to sound nice and solid again?
Old Aug 21, 2003 | 10:44 AM
Full Race EG's Avatar
Default Re: Integra window rattles when i close door... (SilverDc2)
i hate the **** my passenger side window does the same thing. It sounds like it is going to shatter. sucks
Old Aug 21, 2003 | 10:45 AM
acuraholic's Avatar
Interesting. I don't remember mine ever sounding solid when they weren't all the way up, and I bought the car new. Maybe you should get rid of the Solobaric.
Old Aug 21, 2003 | 10:56 AM
timmy8151's Avatar
If you open up your door panel, you should see a plastic strip that has fallen off your window track. Just reglue the strip back onto the track and the rattles should go away. If this doesn't work, then you may need to replace your window guides.
Old Aug 21, 2003 | 11:09 AM
ebelp's Avatar
Default Re: Integra window rattles when i close door... (timmy8151)
I believe this will answer all your questions.
http://www.team-integra.net./s...D=552
Old Aug 21, 2003 | 11:30 AM
Heisdan's Avatar
great post ebelp.. I love TIs articles.. not much else.. (o and their picture section)
Old Aug 21, 2003 | 11:59 AM
integraL's Avatar
Default Re: (Heisdan)
my windows only rattle when they're open. when they're closed they are fine. does this mean my plastic thing fell off?
Old Aug 21, 2003 | 01:59 PM
oMek's Avatar
Default Re: (integraL)
mine rattled, and i did what the articule said, it was right the plastic striping was sitting on the bottom of door, just hade to glue it back in
Old Aug 21, 2003 | 04:28 PM
Dra6on45's Avatar
my window rattles when I use the switch to make it go up and down, should I jus do as stated above and on the TI page?
Old Aug 21, 2003 | 04:29 PM
Dra6on45's Avatar
and it's only on the passenger side, the driver side is tight and snugg
GraphiteMW
Jun 22, 2009 05:26 PM
Lightsped
Aug 28, 2008 11:14 AM
hott-nix
Apr 3, 2005 04:04 PM
gsrhunny
Oct 2, 2002 11:23 AM
RATEDR
May 23, 2002 06:39 AM
