Whole car shakes when im braking from high speeds
Old Aug 21, 2003 | 10:13 AM
SuShiBoiiii's Avatar
Default Whole car shakes when im braking from high speeds
So if im driving like around 70+ and im about to go on to an off ramp from the freeway or sumthin mah whole cabin shakes..i feel it and so do all the people that sit in mah car...so what is that? are my brake rotors warped? should i get new ones? or wuts up sum help would be koo...thx...
Old Aug 21, 2003 | 11:08 AM
r1emperor's Avatar
You need new rotors.
Old Aug 21, 2003 | 11:09 AM
btlfed1's Avatar
Default Re: (r1emperor)
your rotors are probally warped and you either need to have them resurfaced or replaced.
Old Aug 21, 2003 | 12:25 PM
EGPrelude's Avatar
it would be a better value to replace them than to just resurface them since new rotors aren't that expensive anyway
Old Aug 21, 2003 | 12:56 PM
brnadon flanigin's Avatar
Default Re: Whole car shakes when im braking from high speeds (SuShiBoiiii)
ok, so first check the rotors, but i had the same problem and the rotors were fine. So then i changed out the hub, bering and rotor and that fixed it in a hurry....just a thought...
Old Aug 21, 2003 | 04:21 PM
SteveD's Avatar
Default Re: Whole car shakes when im braking from high speeds (brnadon flanigin)
Have you had your tires rotated or wheels removed lately while servicing your car? Many 'shops' dont torque the wheels right and end up warping the rotors. My CRX had same problem after a shop over tightened wheels (esp. while wheels , etc. are still warm from use). From now on they only use torque stix or a torque wrench and follow the right pattern tightening the lugs.
Old Aug 21, 2003 | 05:08 PM
accordboi's Avatar
Default Re: Whole car shakes when im braking from high speeds (SteveD)
like they say, its probably that the rotor is warped. You can have it evened out or just replace them. Why not go cross drilled/slotted?
Old Aug 21, 2003 | 07:39 PM
aaaallll04's Avatar
Default Re: Whole car shakes when im braking from high speeds (accordboi)
if your rotors were warped, then you would feel a pulsation of the whole car when you come to a slow stop. But for the high speed braking, im pretty sure it is your tires. Go get your tires check out, and if nothing is wrong, then rotors.
Old Aug 21, 2003 | 07:45 PM
ddua's Avatar
rotors problem, might need to replace it
MUGEN_EG95
Honda Civic (2006 - 2015)
13
Apr 20, 2008 10:15 PM
The Epidemic
25
Sep 3, 2007 04:24 AM
Civicracer17
Oct 26, 2006 05:13 PM
DIP_SET FoReVr
Oct 6, 2003 08:58 AM
onyx00
Jan 11, 2002 05:58 PM
