bolt size
Just go to the hardware store for Grade 8 or 10 flange bolts or bolt/washer combo. It's faster and probably cheaper.
M10x1.25x45mm or 50mm, whichever one they have.
Yes 45 is the right bolt you are looking at. So it is a M10x45 for the stock bolt so you are going to need a M10x50 or 55 and then either cut it done alittle shorter if you need to. I would find a grade 8 flange bolt if you could, just make sure the bolts are a grade 8 and you will be fine. Just make sure to keep an eye on how much thread is holding, you need to have at least the same amount of thread holding as the deepness of the head on the bolt, but more thread holding is always better.
BLUE EH3
13
Jun 6, 2005 02:04 PM
racekar
16
Jun 21, 2004 09:07 AM
