FYI: Removing the ECM/FI Fuse Did Not Reset My ECU
Old Aug 21, 2003 | 08:13 AM
CPR's Avatar
CPR
Default FYI: Removing the ECM/FI Fuse Did Not Reset My ECU
I removed the 15amp ECM/FI fuse for a total of 4 days and it didn't turn off my CEL. Interesting...
Old Aug 21, 2003 | 08:15 AM
Chris N's Avatar
Default Re: FYI: Removing the ECM/FI Fuse Did Not Reset My ECU (CPR)
What CEL do you have?
What about if you disconnect the negative battery terminal, does it turn off the CEL after that?
Old Aug 21, 2003 | 08:17 AM
CPR's Avatar
CPR
Default Re: FYI: Removing the ECM/FI Fuse Did Not Reset My ECU (Chris N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N &raquo;</TD></TR><TR><TD CLASS="quote">What CEL do you have?
What about if you disconnect the negative battery terminal, does it turn off the CEL after that?</TD></TR></TABLE>
Just the standard code 67(catalyst problem). I removed the fuse not really to get rid of the code but just as a security measure since I was out of town for 4 days. I've removed the (-) terminal before and that does in fact turn off the CEL.
Old Aug 21, 2003 | 08:27 AM
kekek-20's Avatar
New User
are you sure your ecu isn't resetting.. then when you start up it throws the code again b/c the problem still exists?
Old Aug 21, 2003 | 09:02 AM
sackdz's Avatar
Default Re: FYI: Removing the ECM/FI Fuse Did Not Reset My ECU (kekek-20)
That fuse kills the main power to the ECU, not the backup power. It's off when they ignition is off anyway. Remove the 7.5A fuse under the hood marked "backup" for 2 seconds and it will reset.
Or, disconnect the battery for 2 seconds.
Old Aug 21, 2003 | 09:04 AM
xjohnx's Avatar
When i had to do it, it was the "Hazard" fuse, if memory serves correct.
greeen ranger
Jun 16, 2013 06:38 PM
Playa_FL
Nov 9, 2006 06:47 PM
dj626
Sep 27, 2004 03:31 PM
Hybrid 350GT
Jan 18, 2003 03:02 PM
Bbasso
Jan 1, 2003 03:21 PM
