like this race header?
Old Aug 21, 2003 | 07:15 AM
ghettoracer's Avatar
Banned
From: at last finally back to sweet home, sunny north cali, usa
Default like this race header?
i'm not sure if this header's been shown before. just something a little different.
Old Aug 21, 2003 | 07:19 AM
motore's Avatar
Default Re: like this race header? (GhettoRacer)
someone has that in my area coming out the front
cool sound
but his is a turbo car
Old Aug 21, 2003 | 08:02 AM
AllMotorMadness's Avatar
Looks like Danny's (DTR) Headers and his motor?
Old Aug 21, 2003 | 08:16 AM
badCRX's Avatar
New User
Default Re: like this race header? (AllMotorMadness)
Looks like the one on Cloyse's car. What does the vacuum hose do for the motor?
Old Aug 21, 2003 | 08:21 AM
Benny Hinn's Avatar
Default Re: like this race header? (badCRX)
it uses the low pressure caused by the exhaust gasses running over the spigot to vent the crankcase with a small amount of "suction"
Old Aug 21, 2003 | 09:04 AM
ShoeGuy#1's Avatar
Default Re: like this race header? (Benny Hinn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Benny Hinn &raquo;</TD></TR><TR><TD CLASS="quote">it uses the low pressure caused by the exhaust gasses running over the spigot to vent the crankcase with a small amount of "suction"</TD></TR></TABLE>
We had it installed on our car too and found out it just didn't work... we have since scrapped it... for some reason we lost power with it installed...
Old Aug 21, 2003 | 09:07 AM
Banned
Default Re: like this race header? (DVSshoeco)
have you guys try an actual vaccume pump yet?
danny's trying this 'cause his oil dip stick is poping out and making a mess...
btw, i'm going to update my good old Honda Drag Registry http://g-speed.com/pbh/fastest soon and make it dynamic (db back end). i'll ask you guys to submit some time slips soon.
Old Aug 21, 2003 | 09:23 AM
owen_the_soyboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GhettoRacer &raquo;</TD></TR><TR><TD CLASS="quote">danny's trying this 'cause his oil dip stick is poping out and making a mess...
</TD></TR></TABLE> shouldnt he have the tube connected to the crankcase rather than the valvecover?
Old Aug 21, 2003 | 09:49 AM
Lip's Avatar
Lip
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GhettoRacer &raquo;</TD></TR><TR><TD CLASS="quote">have you guys try an actual vaccume pump yet?
wow that sure is old frank. sorta forgot about it. i was rocking 13.3's!!!!! with the itr powa in 99
Old Aug 21, 2003 | 09:55 AM
ShoeGuy#1's Avatar
A vaccum pump will go on the car soon... we haven't added one yet... actually the rules just allowed to do that... So hopefully soon! i will check out the registry... sounds like a good thing!
Old Aug 21, 2003 | 11:45 AM
xJ.SLOTHx's Avatar
yummy lookin header
Old Aug 21, 2003 | 12:37 PM
Benny Hinn's Avatar
Default Re: like this race header? (owen_the_soyboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by owen_the_soyboy &raquo;</TD></TR><TR><TD CLASS="quote"> shouldnt he have the tube connected to the crankcase rather than the valvecover?</TD></TR></TABLE>
The crankcase communicates to the valve cover vents through large oil drainage passages from the head to oilpan.
Old Aug 21, 2003 | 03:53 PM
chris@allmotor.net's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DVSshoeco &raquo;</TD></TR><TR><TD CLASS="quote">
A vaccum pump will go on the car soon... we haven't added one yet... actually the rules just allowed to do that... So hopefully soon! i will check out the registry... sounds like a good thing!</TD></TR></TABLE>
wow, i member asking about this very subject not to long ago, and everyone was like "its against the rules to race with a crankcase vaccumm"...so i sorta left it alone.
Old Aug 21, 2003 | 05:17 PM
216.226.142.95:27016's Avatar
Default Re: like this race header? (chris@allmotor.net)
what advantage does a crankcase vaccum offer?
Old Aug 21, 2003 | 05:33 PM
zad5's Avatar
Default Re: like this race header? (216.226.142.95:27016)
"2-liter engines produce tremendous crankcase pressures at high rpm levels, so we've plumbed this engine with our valve cover vent system to make life easier on it." - endyn (from endyns site - http://www.theoldone.com ) sry dont know how to resize
Old Aug 21, 2003 | 07:11 PM
ShoeGuy#1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chris@allmotor.net &raquo;</TD></TR><TR><TD CLASS="quote">
wow, i member asking about this very subject not to long ago, and everyone was like "its against the rules to race with a crankcase vaccumm"...so i sorta left it alone.</TD></TR></TABLE>
it was just made legal in the NHRA since the Texas Event 2 weeks ago....
Old Aug 21, 2003 | 11:10 PM
evilxkid's Avatar
i like the header, what size steps are in the primaries.
o'h ya the preshure build up in the crank case creats ring flutter and causes blow by.
Old Aug 22, 2003 | 02:31 AM
Benny Hinn's Avatar
Default Re: like this race header? (evilxkid)
blow by creates crank case pressure.
positive crankcase pressure leads to pumping losses as well as losing more ring seal, which can then lead to more blow by, ring flutter, and detonation.
Old Aug 22, 2003 | 06:58 AM
darkSol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GhettoRacer &raquo;</TD></TR><TR><TD CLASS="quote">btw, i'm going to update my good old Honda Drag Registry http://g-speed.com/pbh/fastest soon and make it dynamic (db back end). i'll ask you guys to submit some time slips soon.</TD></TR></TABLE>
Frank, you've been my hero for the past seven years
Update it! I've been waiting for over 3 years for that to happen! Gonna hit 11's next year in the Sol "full (cough cough) interior" 0.438 seconds to go...
Old Aug 22, 2003 | 07:48 AM
Banned
Default Re: like this race header? (darkSol)
yo dave!! sups sup. i still keep an eye on you and visits. drag registry will be made dynamic "really soon now" (tm). did some one make the CF trunklids, or no? there were always talks here and there, nothing came out right?!
next year is going to be big for me... i hope.
Old Aug 22, 2003 | 12:08 PM
badCRX's Avatar
New User
Fiber Images made some of the CF trunk lids for the del Sol.
Old Aug 22, 2003 | 12:09 PM
Banned
got any links to the trunk lids?
Old Aug 22, 2003 | 07:11 PM
T4eg's Avatar
nice
Kurly
Apr 20, 2008 10:29 AM
Tyler Con
16
Sep 4, 2007 08:56 PM
tnsxsear1
24
Nov 21, 2004 08:11 PM
civic91
Jan 20, 2004 05:51 PM
d16a6
11
Nov 16, 2003 01:37 AM
