oil pump/ timing belt gear and crank pulley???
is there suppose to be two keys for each the crank pulley and the oil/ timming belt gear? or just one long one on the type r motor? i have a new one from acura but it seems to be too short only enough to fit the crank pulley and not the timming belt gear...doesn't the timming belt gear have one too?
OBD-2 motors that have a CKF sensor have two keys. One for the timing belt sprocket/CKF tooth gear and then another key for the crankshaft pulley.
