setting valves with adj. cam gear
should i set the cam timing back to zero before i adjust the valves on my d16z6 (intake .007 exhaust .009) i have my cam retarded 2degrees and was wondering if i should set it back to zero before adjusted my valves
thanks larry
thanks larry
is it going to make that much of a diff? or should i just set my cam timing back to zero and adjust the valves and then retard the cam 2 degrees? i dont really understand what you meen
rtiadnoh
Mar 16, 2004 07:24 AM
