Stock 99 B16 turbo ?
Old Aug 20, 2003 | 05:58 PM
2000CTRSi's Avatar
Default Stock 99 B16 turbo ?
I have a 99 civic Si and putting on custom kit tomorrow. Wondering how many pounds should i run safely for a while if my motor has 73000 on it and i am using a turbonetics t3/t4 E housing... HELP!
Old Aug 20, 2003 | 06:18 PM
drvfast's Avatar
Default Re: Stock 99 B16 turbo ? (2000CTRSi)
6-7 psi get it tuned as soon as u can
Old Aug 20, 2003 | 07:45 PM
2000CTRSi's Avatar
i also need to tap my oil pan... how should i go about doing that... i have a tapped oil pan off of one of my LS/VTEC's but i'm using the 1.6 bottom end.
Old Aug 20, 2003 | 07:54 PM
RenoRacing's Avatar
Default Re: (2000CTRSi)
oil pans are interchangable!
Old Aug 20, 2003 | 08:19 PM
tslag's Avatar
don't run more than 8lbs unless it is dyno'ed and tuned by a reputable shop. Also check your timing and make sure you have enough fuel. I blew my stock piston ring landings @ 9psi. It sucked.
Fantastic420
Oct 6, 2009 11:42 PM
tekstyle
May 2, 2006 09:34 PM
JohnShaft
Nov 3, 2001 09:54 AM
